2019 Ram 1500 Signature lights
jfigster
The bottom left signature light is out on my truck. Is there a way to turn both the left and right bottom lights off or would be better to have it fixed?
Thanks
I do not believe you can turn just one off.
Thanks, was thinking if atleast the bottom on both sides would be off it wouldn't look that bad.
Thanks again.
You can turn it off, but when your headlights are on it still might turn on not 100% sure.
Thanks, I'll try turning them off after I work on my bed lights. I'll let you know how it works out.
I have mine turned off because I use my blinkers as DRL.
There a line in Alfaobd for signature lights to disable them.
