2019 Ram 1500 limited 5.7 L w/ e torque Pulsar in-line chip issues
Taustin87
Hi there, just had a pulsar in-line performance chip installed and seemed to have lost all my climate, usb connections, cameras, heated and cooled seats for the passenger. I called the numbers provided in the box, was told it self learns again, can anyone on here confirm this?
cheers!!
popcenator
Omaha, NE
If you mean the icons have all disappeared then that's a byproduct of disconnecting the battery, they'll reappear in the next few start ups.
Taustin87
That depends. Did you properly disconnect the battery and discharge residuals before unplugging the ECU?
Steve
It was done at a shop in calgary here, I assume they disconnected the negative terminal from the battery. Buddy says he did anyways.
