2019 ram 1500 Laramie ac blowing only from defrost
Ksoto033
Hi there, kind of few things together happening wrong at the same time, truck was jumped 2 times, second time jumper was removed and shut off. From there ac starts blowing from defrost, hot on passenger side and cold on driver side, i tried to change the air to blow from ac vents or floor, i can hear the blend actuator clicking? Any help?
Sounds like your blend door is having issues, especially with multiple clicking sounds.
In 4th gen, it's easy to change out, not sure in the 5th gen.
How long since the battery was disconnected? Often it does take several hours to overnight for everything to come back online after a battery disconnection.
I always mention this when dealing with a battery or power issue, make sure you check the circuit breaker box in the engine bay, make sure all the bolts are tight and none are missing.
