2019 Ram 1500 Big Horn DT 6 Factory Speaker Post Upgrade Issues
HookedonRam
NV
So, after watching this guy
I decided to go with the same setup. However, now, I get this audible sound even when the radio is turned off. There is like a vibration sound of some sort. I don't know how to fix it or where to look even. But if I am idling it sounds loud or when I push the gas I can hear it. Is it messing with my "active noise cancelling" module or something? If so, how do I fix it? Thanks in advance!
HemiDude
Ohio
That sound exactly like the ANC - I understand it doesn't play well with sound system add ons. I haven't upgraded my base sound system yet but I did have the issue where the sound was flat or distorted when I turned the volume up over 23. I installed an ANC bypass I found on the Crutchfield site and it took care of that. My advice would be to start there - for $20 you can't go wrong.
myles
Definitely sounds like ANC, there's a few forums on here where people cut a wire under the driver's seat to get rid of it. Not sure which wire though.
Bigski74
I'm in exactly the same situation, I installed the same infinity speakers and now I have this loud low base sound, I was thinking I would need to take it to the dealership to see if there is anything they can do, but only as a last resort. I would definitely be interested in a fix or solution without having to reinstall the factory speakers.
