2019 Limited 1500, RF Hub or not
Jarka700@
Hello :)
I’m a new owner of a 2019 RAM Limited from Lithuania. I bought the car after an accident in Texas. I'm repairing the vehicle myself in my garage, and I’ve run into a problem.
When the car was transported to me, it was running and starting fine. I disassembled the front, replaced the damaged parts with new ones, and now I want to start it — but nothing happens. The Start-Stop button is blinking "off," and the gear selector switch is also blinking. The interior lights are working, but the radio screen flickers strangely.
I read on a forum that the problem might be with the RF Hub. The battery is charged to 12.70 V, and all ground connections have been checked. Could the issue be caused by the front and rear parking sensors and cameras not being connected? The airbags have not been replaced yet. The car was welded, but the battery was completely removed during the process. Could there be a specific place I should check that I might not be aware of?
Hello :)
Get alfaobd, compatible OBDII interface and a SGW cable, see what codes are popping up and or modules not communicating.
These are what I use.
AlfaOBD
Amazon.com
Amazon.com
