2019 laramie. 285/60/20 BFG K02. Leveling kit??
Patrwood
So I finally pulled the trigger on a set of tires. I had been reading for weeks on what size a tire I could run without rubbing. (Factory suspension, no air) I had read that the 275/55/20 would not rub but the But the 285/60/20 would be a bit shorter but yet a wider look, which I would prefer. So I bit the bullet and am now testing the 285/60/20 and I will say they do rub at full lock In reverse. Nothing major bu they do rub. Also I did not take into consideration the factory mudflaps... now they rub both sides so I will have to do some trimming or wait until I level the truck. What do you guys suggest for a leveling kit??? I want to maintain the best ride possible! Thanks!20191012_115027.jpgIMG_0162.jpgIMG_0160.jpgIMG_0159.jpg
Nice looking truck, my one question before I make a suggestion is what’s your budget lift wise ?
Well I'm not to sure. I've been quoted fr a ready lift with alignment 450 I think it was
Nice truck heres mine same color 2019 laramie with 285/65R20 and 2 inch motofab leveling kit
