2019 HK 19 Speaker System factory connectors
McBee
Just purchased a used 2019 DT 1500 Limited. It "has" the 19 Speaker HK sound system, unfortunately, the previous owner replaced it with aftermarket and ripped all his components out before trading it in. I have 4 replacement factory HK 6x9s for all 4 doors, however the factory speaker connectors were cut off.
Does anyone know of any factor speaker connectors? All the ones I can find are NOT for the premium HK speakers.
Thanks!
@Infotainment
Is 174921-1 the part number for the connector itself? The OEM part number for the 6x9 door speakers (all four doors use the same speaker) is 68590588AA if you have the 19 Speaker HK system.
@Infotainment
Yes, 174921-1 is the connector itself used for all the speakers while 174463-3 is 2 pin version used for the tweeters. Tweeters are 68043031AC, and 3.5" speakers are 68584767AA
If it helps anyone, it appears Mopar makes an official 3 Way Wiring Repair pigtail for situations where the factory HK speaker connector was cut off. It's Part Number: 68030096AA.
