2018 Rebel
Ducatirider
OK everyone, Ive researched and cant get a straight answer. Does 4wd lock, Lock the rear differential? As in you now have posi traction rear end? LIke both tires spin together? Im use to limited slip in 4wd mode but unsure of 4wd Lock. Thank you.
Fatherof3
Ontario Canada
Welcome , It locks all 4 wheels not just the rear .
2019REBEL
ON, Canada
No it doesn't...lol. 4WD Lock is just 4WD. It will put it in 4WD, so usually 1 front tire and 1 rear tire unless you have LSD in the rear which will technically have both rear wheels with one slipping before the other engages. Only way to lock the rear is with rear differential lock so you will have 3 wheels moving you. Does your 2018 Rebel have rear differential lock like the 2019's.
