1300 Watt Amp
cfederico
I have a 2023 Ram 1500 Big Horn with Etorque. I have the 12" Uconnect. I have replaced all 4 door speakers with Kicker KS Series 6x9's, Front dash corners with Kicker KS Series 3 1/2's and rear headliner speakers with Kenwood Excelon 3 1/2's. I have a Kicker Comp R 10" 2 Ohm sub. My Amplifiers I currently have are Kickers. They are the 4cxa800.1t for the sub and 46cxa360.4t for the rest of the speakers. I also have the PAC Amp pro in order to connect the amps to the stereo.
My question is if I replace both the amps that I have now with the Kicker 51LX1300.7, a 1300 watt amp will the electrical system be able to handle this. I looked on line and can't find a definitive answer. I wanted to see if anyone on here has installed a 1300 watt amp and if the electrical system handles it.
Being that this truck doesn't have a traditional alternator I'm not sure if this will work because I'm not sure if that make upgraded generators for the Etorque.
If you have FB, Check out this 5th Gen Audio Group
