1” Rear Drop?
willfosterr
So I have a 2019 crew cab and I’m wanting to level the front and drop the rear 1”. Since they don’t make 1” drop springs I had the idea to get a 2” drop spring and get a 1” rear lift block. All the ones I can find are for 4th gens, I read somewhere they work but not sure. Do they work, and if not would there be an easier way to do it?
Not sure about the lift block, but the rear end looks pretty much unchanged from last gen. I did the 2" drop springs and its closer to 1.5" on my Bighorn quad cab. An "easier" way is to cut a coil out of the spring for a 1" drop
