- Apr 18, 2020
If you’ve been wanting to upgrade your factory halogen fog lights to true OEM Mopar LED fog lamps, this is hands-down one of the cleanest and most factory-correct lighting upgrades you can do for your Ram.
Infotainment.com offers a complete plug-and-play LED fog lamp kit designed specifically for the Ram 1500 and HD. This is not a cheap aftermarket swap, these are genuine Mopar LED fog lights, built to match factory LED headlights, improve nighttime visibility, and give your truck a much more modern look.
Whether you’re running a work truck, off-road build, tow rig, or daily driver… this upgrade makes a big difference.
This kit includes factory OEM Mopar LED fog lamps paired with a direct plug-and-play harness for a perfect fit.
No cutting. No splicing. No modification.
Why upgrade?
Because the truck wasn’t originally programmed for LED fog lights, Infotainment includes their OBD Genie programmer. Plug it into your OBD port and the truck automatically configures itself for LED operation — no flickering, no warnings, no guesswork.
Most Ram owners will find this install very manageable with basic hand tools.
Have Questions?
Our U.S.-based team is ready to help:
Call: 1-855-636-6287
Email: [email protected]
Live Chat: available on our website during business hours
Product Description
This kit includes factory OEM Mopar LED fog lamps paired with a direct plug-and-play harness for a perfect fit.No cutting. No splicing. No modification.
Why upgrade?
- Major improvement in clarity and visibility in rain, fog, snow, and dark roads
- Crisp white OEM LED output that finally matches modern Ram headlights
- Exact factory fitment — same brackets, same connectors, same aim adjustment
- Fully sealed, durable housings designed for long-term reliability
Product Features
- Genuine Mopar LED Fog Lamps — not aftermarket replicas
- Plug-and-Play Installation — no wiring modifications
- Works on Ram 1500, 2500, and 3500 (various trims supported)
- Full compatibility with factory headlight and lighting systems
- OBD Genie programming tool included
- Matches OEM LED color temperature and pattern
- Improved visibility and a clean modern appearance
Installation Overview (Difficulty: 2/5)
Most Ram owners will find this install very manageable with basic hand tools.Ram 1500 Installation Guide
Ram Heavy Duty Installation Guide
