- Apr 18, 2020
Hey Ram Owners,
Parking a heavy-duty truck is no joke—tight spots, blind corners, and massive bumpers make precision a challenge. That’s where the Factory OEM ParkSense Front & Rear Park Assist System comes in. Designed by Mopar and available at Infotainment.com, this upgrade adds factory-quality sensors and alerts to your Ram 1500 or HD, giving you confidence every time you pull into (or back out of) a space.
ParkSense uses ultrasonic sensors embedded in the front and rear bumpers to detect objects you can’t easily see from the driver’s seat. When obstacles are in range, you’ll be alerted both audibly (chimes that get faster as you approach) and visually (cluster display graphics).
Key benefits include:
We rate this installation a 4 out of 5 for difficulty. It’s absolutely DIY-capable if you’ve got some tools, patience, and maybe a buddy to lend a hand when removing the heavy front bumper. Here’s a quick overview based on our install:
Have Questions?
Our U.S.-based team is ready to help:
Call: 1-855-636-6287
Email: [email protected]
Live Chat: available on our website during business hours
What Is ParkSense?
ParkSense uses ultrasonic sensors embedded in the front and rear bumpers to detect objects you can’t easily see from the driver’s seat. When obstacles are in range, you’ll be alerted both audibly (chimes that get faster as you approach) and visually (cluster display graphics).Key benefits include:
- Factory-style integration with your Ram’s radio and instrument cluster
- Adjustable chime volume (Low / Medium / High) via the radio settings
- Automatic activation in Drive or Reverse below ~7 mph
- Seamless plug & play wiring harnesses with OEM-fit shrouds and fascia
Installation Details
Package Contents
- OEM front sensor shrouds (fog light bezels)
- OEM lower bumper fascia with integrated sensors
- Rear bumper valance with integrated sensors
- OEM-grade wiring harnesses (front & rear)
- ParkSense control module
- OBD Genie Programmer + SGW bypass for programming
- Full step-by-step video support
Why Add ParkSense to Your Ram HD?
- Extra confidence parking a long-bed crew cab in tight spaces
- Avoid costly bumper damage from unseen obstacles
- Keep the factory look & functionality
- Retain full OEM control through your Uconnect system
