🚘Transform Your Ram’s Rear View: OEM Digital Mirror Now Available!
Infotainment
5thGenRams Vendor
5thGenRams Vendor
Hey Ram Owners!
If you're here, chances are you're just as passionate about upgrading your truck’s safety and tech as we are at Infotainment.com. Today we’re excited to introduce a sleek factory-fit OEM upgrade that blends style, safety, and simplicity: the Digital Rear View Mirror Upgrade for 2021–2024 Ram 1500 DT and Heavy-Duty trucks. Whether you’re hauling gear, towing a trailer, or just cruising your favorite highway, this upgrade provides a crystal-clear digital feed from your third brake light, improving visibility far beyond your standard mirror. And yes—it’s 100% plug & play and looks just like it came off the factory floor (option code GRG).
🔧 What’s in the Box?
We’ve designed this kit to make your install as seamless as possible—perfect for DIYers:
  • Brand-new OEM Digital Rear View Mirror
  • Factory-style Third Brake Light with Integrated Camera
  • Custom-fit Video Cable (pre-terminated for a simple install)
  • Step-by-step installation video guide with helpful tips for routing, mounting, and testing
📽️ Why This Upgrade Rocks
  • Full-screen digital video feed straight from the third brake light
  • Boosts rear visibility—perfect for towing or reversing in tight spaces
  • Includes a brightness & vertical position adjustment directly on the mirror
  • Instantly switch between digital view and traditional mirror with a tap
  • OEM look and feel—just like Ram intended
🛠️ Installation Made Simple
All you need are some basic tools like zip ties, a panel tool, tape, and a Phillips screwdriver. Even if your truck doesn’t have a sunroof, routing the cable is easy thanks to our tips in the video. Already have an auto-dim mirror? You're good to go! (If not, check our product page for optional header wiring and mirror covers.)
👀 Factory Look Meets Real-World Function
The included third brake light not only adds aggressive styling with LED lighting, but it also improves your truck's rearward awareness—day or night. Whether you're in reverse or just want a better view of what’s behind, this system gives you the visibility (and confidence) your truck deserves.
💪 Built for Ram Enthusiasts, by Ram Enthusiasts
At Infotainment.com, we’re all about empowering truck owners to upgrade on their terms—no dealership required. That means:
  • Genuine OEM parts for that perfect factory fit
  • DIY-friendly kits with all the essentials
  • Knowledgeable support from truck fans just like you
Questions? We’ve got your back:
📞 Call us at 855-636-6287
💬 Live chat with our US-based team
📧 Email us at [email protected]
Stay safe and keep upgrading,
The Infotainment Team 😎
