🍂STEPtember Spectacular Savings at RealTruck!🍁
Realtruck
Get ready, 5th Gen Ram! It’s that time of year again- and, no, I don’t mean pumpkin spice season! STEPtember is live, and the promos are unbeatable! It’s all about giving you the best deals on the products you’ve had your eye on all year long. Now is the time to upgrade your truck and add some serious style!
I’m super excited about this month! Adding steps to your truck is more than just a style upgrade- it’s a practical enhancement that offers both convenience and safety. Adding sturdy running boards or nerf bars makes getting in and out of your truck that much easier. Whether it’s lifted, stock, leveled- you and your passengers will appreciate a more comfortable entry.
AMP Research PowerStep™
AMP Research continues to provide you with innovative and exciting products that you can rely on. The AMP Research PowerStep™ running boards are no exception! The single-motor design automatically deploys and retracts your steps with ease. Step onto a 6” wide black PTFE non-slip surface that’s brilliantly illuminated at the front and rear row with LED lights. The PowerStep drops lower than standard running boards, making these the perfect addition to your lifted Ram.
full link:AMP Research PowerStep™ | RealTruck
AMP Research PowerStep™ Override Switch
Add the optional AMP Research PowerStep™ Override Switch for manual control- so that when you’re in a bind out on the trails, you don’t have to worry about your PowerStep deploying where it shouldn’t.
full link:AMP Research PowerStep™ Override Switch | RealTruck
N-Fab Black EpYx Steps
The EpYx Steps combine a sharp, modern look with the comfort of a wide, secure step. Effortlessly hop up into your cab or climb down on its extra-long 15” step pad. The EpYx are built tough! It’s an all-steel construction, and the main tube is designed with welded-closed ends caps and a black powder coat finish to withstand the harshest of conditions.
These steps are a HOT item this month, and there are a limited number available! Get them while they last!
full link:N-Fab Black EpYx Steps | RealTruck
N-Fab Nerf Step RS
The N-Fab Nerf Step RS is for the truck that demands both rugged durability and sleek style. Featuring a modern, cab-length design with a drop-down step, the Nerf Step RS provides easy access to your truck and a clean, streamlined look. Built with heavy-duty steel and finished with a textured black powder coat, these steps are tough enough to handle extreme elements and resist corrosion. Installation is a simple bolt-on style that doesn’t require drilling. Take on rough terrain and boost your ride with a striking appearance by adding the N-Fab Nerf Step RS while they’re in stock!
full link:N-Fab Nerf Step RS | RealTruck
Go Rhino RB10 Slim Running Boards
Your Ram takes you wherever you want to go- do it in style with premium protection! These sleek, low-profile running boards feature the same aggressive styling—directly inspired by the off-road-ready Ford F-150 Raptor—as the brand's other RB series steps. A slim 4” step highlights the raw edge that your Ram brings to the trails.
full link: Go Rhino RB10 Slim Running Boards | RealTruck
📞Your Ram called- it wants a Nerf Step makeover! And who are we to say "no" to a truck? 😌😌
🔥🔥With an event this BIG, you can’t afford to miss out! 🔥🔥
📣 PM me directly or feel free to email me with all your questions- shipping times, installation, pricing quotes, and all! I’m standing-by, ready to ensure that you receive a perfect fit and a product that matches your truck’s performance and style.
I can’t wait to see how your new steps look on your Ram!
