Change it before the trip.Does anyone know how many "miles to go" when you get down to 5% oil life remaining, just wondering if I should change the oil before or after my trip of about 1900 miles?
Don't worry about what % as much as you care about how many miles since the last change. If you tow a lot, change it around 5-7K. If you don't, change it around 7-10k. To answer your question, yes most likely an additional 1900 miles will bring that number to 0% - simple math you have probably around 17 more run hours on the motor and about 500 miles before 5% becomes 0%.Does anyone know how many "miles to go" when you get down to 5% oil life remaining, just wondering if I should change the oil before or after my trip of about 1900 miles?
I wish I would’ve known that when I traded in my 2015 with over 140K on it, zero motor issues, and the whole time I only changed it with 10% or less oil life…with…gasp…conventional oil.you let you monitor get down to 5%. if you care about the truck and want it to last best thing to do is change it every 5000 miles, forget that oil life display is there.
that close, with that long of a trip, just get it changed. I personally wouldn't let iy go much last 10% oil life, if I was following oil life monitor. But I change mine at 7500 milesDoes anyone know how many "miles to go" when you get down to 5% oil life remaining, just wondering if I should change the oil before or after my trip of about 1900 miles?
Yup generally regardless of miles you should change it once a year.My daily commute is too short to let the oil go to 7500 or 10k miles.
i get it. my buddy has a 2012 ram with 250k on it and climbing, motor and trans have never been apart it don't burn or leak a drop. 5k on oil and 50k on trans services.I wish I would’ve known that when I traded in my 2015 with over 140K on it, zero motor issues, and the whole time I only changed it with 10% or less oil life…with…gasp…conventional oil.
If it was simple math, 5% of 10,000 miles would be 500 miles. From what I've seen, if you don't use your truck for towing or drive in extreme conditions the oil life monitor pretty closely tracks with mileage. Even if you wanted to stretch your OCI to the max on the oil change monitor, the best you'd have is another 500 miles before it reaches 0%.Just FYI I do take care of my engines I have several cars I switched to synthetic motor oil specifically mobile one back when it started I think 2004. But I also had the oil tested in two of my cars several times and the testing facility kept telling me to push the oil change interval all the way to 10,000 miles and that's where I change it now is 10,000 miles. So synthetic oil does cost a little more but why do it three or four times in within 10,000 miles when you can do it just once. My only question here was about the gauge on the dash I just had no idea what 5% of oil life meant. Thanks for all the help.
Sent from my SM-S918U using Tapatalk
big debate.
so back in the day 3k was the thing and motors were worn pretty good at around 100k. it's funny they say 50's and 60's were good cars but very few made it to 150k. since the late 80's longevity has increased by leaps and bounds. i'm 57 so i was a 3k guy and i get it. oil additive packages have also made huge advancements. oil analysis cost as much as it cost me to just change the oil so why would i get one?? as i have said for me it's cheap insurance and piece of mind. i am not a engine builder just a regular guy so no analysis for me. i did not pole them on oil being the cause of failures but from the amount of sludge i saw on the core returns i can guess it's a fair amount.My take..
Everyone is an expert, and everyone has an opinion.
Ask someone the best oil, you’ll get just as many answers.
Ask someone how often to change.. you’ll get nearly as many.
My 2008 had lifetime powertrain. My 2015 had Max Care unlimited (Original owner only, me) My 2023 has 8yr, 125K Max Care.
At or around, 125K, I’ll be trading it in or selling it.
I have zero desire to keep a vehicle beyond that. Warranty or not.. time for something new.
Tech advances are too good for me to keep a truck beyond that.
Now…is that fair to say I don’t care because I won’t be keeping mine past the warranty period? Sure it is.
If I was keeping it past the warranty period, I’d still change it on the same frequency…at or around 10%.
1791..here’s an honest question for you. All the mechanics that say the sweet spot is 5K. Are they the same ones that used to say 3K? How many have had an oil analysis done, which… short of a complete tear down and measure, is the best way to track oil life and performance?
That’s not me being a clown, that’s an honest question…. And of all those motors that were broken/torn down/replaced, how many can undeniably say it was because of oil change intervals stretched too far? Lack of oil? Sure. Wrong kind? Sure.
But properly filled, level maintained and checked, proper type/weight…how many were failures do to oil age and use?
I’m gonna guess there’s no definitive answer on that from dealer mechanics. Just guesses.
