2025 1500 Limited doors will not lock/unlock
CobraKai
Clifton Park, New York
I have a new 2025 ram 1500 limited. Love the truck so far this is my 6th ram. Tonight when leaving work everything worked fine, stopped at gas station for milk for wife baking… shut truck off and locked doors with key fob like I normally do. Came back out hit unlock multiple times and tried the handle the truck mirror lights lit up and running boards came out but none of the doors unlocked. Tried the app still would not unlock.. finally used physical key in the fob and lock worked fine. Truck started up and ran fine. No errors on dash. Get home and I now still cant lock or unlock the other doors.. anybody else ever experience this or any ideas? I tried the other fob as well to no avail.. and of course it’s Christmas Eve so nowhere to bring it and I can’t get my kids in the truck.. lol
try a new battery in each fob, think is a 2032. might wake up the proximity antenna.
I will in the morning after presents. Going to unplug the main battery too see if maybe that resets something.. it’s weird cause it’s picking up the fob the mirror lights turn on and running boards come out but the door locks won’t do anything… with either fob and the app.. but I can unlock the door with physical key and drive the truck… unfortunately the other 3 doors don’t have keyholes…
Can you open them by pulling on the interior door handles?
If the lights and running boards respond to the fob then that should eliminate the fob battery and RF hub.
Interesting to hear what it does after disconnecting the 12 volt battery.
SO I went to put it in the garage this morning to play around with batteries and the freaking doors unlocked! now im nervous though... I mean NOTHING worked to open the other three doors, both fobs, the app, hitting the buttons when I got inside driver side with actual key I still couldn't open or unlock the other three doors... so fobs were working, app was working, truck was responding to everything else I just couldn't unlock the doors. never happened before this. no warning lights, no other issues. this is so weird.
Happened to me last year. Replacing the fob batteries worked, can confirm they are type 2032 buttons.
Copy that, hasn't happened since but maybe I will change the battery just in case. thank you. truck is awesome otherwise! LOVE the twin turbo, feels almost as fast as mY TRX
I have my ritual of when I change my smoke detector batteries, I change my fob batteries too. :)
This just happened to me today and then resolved itself about an hour later. Will replace the fin batteries, but wondering if you ever had the issue again? Thanks
Yes it happened again after I got to work two weeks ago. wouldn't lock my doors with fob or app. had to use physical key again for drivers doors. none of the other doors would do anything. cleared on its own like hour later... no idea whats going on. both cats are being replaced now too lol
What are they replacing the cats? How many miles?
I have 5800 miles on my 2025 limited with high output. they are replacing both of the cats, they didn't say if they were melted or damaged but check engine lights is popping up both codes p0430 and p0420 for each cat. they tried doing some software update for the ignition I believe which didn't fix the issue... won't know until Wednesday if replacing them fixes it or not..
I heard someone with a YouTube channel talking about melting cats but you're the first one on the forum to have the issue. So curious about this. How are they getting so hot? Is it only on trucks driven hard? Only HO engines? First major issue with this engine? Can't wait to hear the diagnosis.
Heard the same, can`t remember the channel.
I hope it's not a widespread issue because I love this new HO engine. It screams! I'm waiting for them to get all the kinks and testing with the tuning process. Burger tuning knows their stuff.
Other potential major issue is thermostats getting stuck closed and burning up the engine.
While I agree a faulty thermostat is not a good thing, if your vehicle is overheating and you continue to drive it until you "burn up the engine", well that is on you.
I believe the issue was, according to the video, was that it was overheating too fast to stop the damage. I don't think it was just driving while overheating.
I dropped it off this morning to replace both of the cats so hopefully I will be having it back later today and let you know. I have never seen any alerts or warnings pop up on dash, I keep the different gauges up on cluster usually and everything has shown normal... I haven't even towed anything yet with this truck or filled the bed up yet! only has 5800 miles on it so the other guy claiming its on me is just ridiculous. I like to floor it every so often but why else would ya want this HO I guess I should've kept my TRX... cats going bad, odometer flashing, locks not unlocking with either fobs, warning systems flashing unavailable every few weeks and have serviced but then going away... sounds like im gonna have electrical issues with this one...
