ChadAllen
- Mar 19, 2022
Got an odd one. I had the hemi tick. Once I was sure it wasn't exhaust, I set about pulling the cylinder head. The valvetrain was fine, no bent push rods, no obvious signs of wear, even the valves looked surprisingly good.
I pulled out the lifters, expecting to see a seized roller.... but no. To my surprise every single roller looked great. No flat spots, no wiggle up/down or side to side, no gritty feeling, all the needles were present. They looked fine.
So I sent a borescope down to inspect the cam lobes.
Here is what I saw on the far back lobe on cylinder 8.
And here is the lifter pulled from that same hole
Again, the lifter is fine. No gouges, no flat spots, no play in the bearing, nothing. What could cause that type of damage to the cam? It almost looks etched. That's not the typical damage you see when a cam lob wears down. I've shown it to three different mechanic friends of mine and none of us can figure out how that could have happened without the lifter being effed. What do the experts here think?
For reference: the engine has 72,000 miles. I'm the only owner and I have changed the oil every 5k with Pennzoil Ultra Platinum. I knew going in that idling was an issue with this engine, so I never let it sit and idle longer than a red light. Correct oil, correct change interval, correct operation.
Also, ignore the date on the photos. I never bothered to set that up on the borescope.
