Looking at a number of issues between Travel Trailers and Fifth wheels. Can anyone provide and MPG data on those two specific options while being towed by a 1500 with a 5.7 HEMI? Thanks
Like others have said, depends on the terrain, and weather conditions. On a good day with no wind and few hills, I can get 13, but that's under extremely favorable conditions. Mostly I get between 10 and 12. But, it also depends on the truck. Not all are apples, and not all are oranges, and trying to compare one to another, well, you know what that is about. Best advice I can giv is keep the speed down. Mine seems to like 55/60 the best. So, have fun and drive safe.Looking at a number of issues between Travel Trailers and Fifth wheels. Can anyone provide and MPG data on those two specific options while being towed by a 1500 with a 5.7 HEMI? Thanks
If you are hauling that around a lot, you should have gotten a heavier duty truck. Not that a 1500 wont pull it and if you are going a couple times a year it will be fine. I know my friend that hauls his around quite a bit has a 2500. It just does it with more ease.
There was a guy here called @SnowBlaZR2 who hauls his vacation home around quite regularly. He went to the dark side and got a Ford that I think he Found On Road Dead. It's the Superduty though. I think he learned that the heavier truck makes RVing better. He still chimes in sometimes. Now that the favorite gear bashing thread is shut down, he may have lost interest here though.
Yep, its just physics.My 22 hemi gets 9 to 11 towing a 21 foot long high profile travel trailer. My previous tow vehicle, a Tacoma got the same. My last travel trailer being towed by a 2005 Silverado got the same as well.
Doubt you will be towing a fiver with a 1500, any 1500/150 period.
But for a 6-9K GVWR bumper pull, expect what the previous commenter told you. RAM sucks for towing with coils, fraid’ that for a “half ton” the F150 is a lot better specced.
Don’t believe the rv salesman, 1500’s are not good platforms for north of 8K.
Oh and do a search for towing on this forum, plenty of threads…
Tail waggin-the-dog is setup, not weight differential. I have , and many people do, tow something heavier than the truck.It’s all been said on payload, etc. I’d add that having a truck that’s close to the gross weight of the trailer will be a nightmare in wind. Part of 2500’s better tow performance is the tail not wagging the dog! For all those quoting tongue wt from a sticker, get thee to a CAT scale! My new Alliance TT claims a tongue wt of 890 and the CAT scale revealed it was almost 1600! It sitting at dealer for warranty work (goodbye summer 2024) but after that I need to have the WD hitch either tweaked or replaced (and no, I wouldn’t recommend Ron Hoover RV to an enemy)
Trailer brakes are required to be sufficient to stop the trailers weight, and when set up properly, are set to an approximate 60% trailer 40% truck differential, in order to keep everything in line in an emergency stop.All good advice. 2500 or better for any 5ver IMHO.
My bro hauls a 32’ Grand Design with a 2500 and uses a HO Cummins with air bags. Tons of power but only 11-12 mpg due to wind resistance.
I have only towed with 3/4 or 1 ton gas but that was 20+ years ago.
The new trucks can “tow the space shuttle” but lack payload and braking ability for big trailers.
Its true that you can successfully tow a heavier trailer for sure, and improper setup on a lighter trailer can really cause you headaches.Tail waggin-the-dog is setup, not weight differential. I have , and many people do, tow something heavier than the truck.
Properly setup is the key, as well as the fact that most trailer brakes are drum not disc and are on 15” wheels, so not a lot of brake area. How many peeps really understand how to set up their brakes and how many will adjust that set up based on differing loaded weights of trailer?Trailer brakes are required to be sufficient to stop the trailers weight, and when set up properly, are set to an approximate 60% trailer 40% truck differential, in order to keep everything in line in an emergency stop.
It's somewhat alarming how many undersized tow vehicles we've seen during our travels. Too many people listening to their dealers and brochures about what they can tow.Its true that you can successfully tow a heavier trailer for sure, and improper setup on a lighter trailer can really cause you headaches.
My point is more that the mass thats behind you that is pushing you or is “fulcrum-ing“ you is a problem for a light weight tow vehicle.
Thats apart from payload issues and thus getting the front end too light.
Just so many issues with not having the right sized truck to start with.
Advertising that an F150 or a 1500 can “tow 12,000” is meaningless when the 12K is based on a flatbed trailer with steel or concrete that sets lower than the trucks’ tailgate. They never take into consideration the frontal area of the trailer, nor do they comment on the wind loads from the side that can move you completely out of your lane when you have a 30’ long 11’ tall “piece of plywood” going down the road.
