Sunroof popping/clicking
Clozano
Last week I started to notice a popping/clicking sound coming from my sunroof. I notice that when I open the sunroof the popping/clicking stops. Has anyone had this problem?
BowDown
Frisco TX
Yes. drove me crazy looking for the issue. Pulled down the headliner, took the CHMSL out and looked above the headliner for loose wires
Ultimately found a f150 video where the guy was having the same issue and used this
About 3 days after spraying the entire pano seal, it stopped
I didn't use a knife though, just stuck the straw in the channel, sprayed and moved down the channel
eye exaggerate
Is there ice on it? Mine was driving me nuts yesterday because of ice.
Clozano
N
Would your truck only make noise when the sunroof was closed? I find that mine will stop making noise if I open my sunroof completely.
BowDown
Frisco TX
N
Yes, only when closed and driving over uneven pavement. If the sun roof was either in vent mode or partially-all the way open, no noise
Traysea84
Any luck on finding out what it was? Mine has been making noise and been to the dealership a few times for this and a front end noise that they tell me they can’t duplicate and it’s all normal and to put the radio. It’s driving me nuts
eye exaggerate
Yes. Mine started last month. I noticed that when I’m going slowly over uneven surfaces it’s making this sound (sunroof is closed when it happens). Going to get some video for reference.
Bay Area RAM
Add me to this list…. Mine just starting to do the same. Mostly when going slightly off camber (speed bumps on one side of truck, steep driveways, etc..) almost like the body is flexing more than it should. My 2019 never did this but this one is a long bed… so ? Doesn’t matter if the roof is open or closed…. It does seem to lessen after driving for awhile, maybe the rubber is warming up…
gonna buy the lube today and try it out.
Bay Area RAM
Well I tried the lube in the video….. lubed the crap out of everything and it didn’t do a thing…. Still pops and creaks when the body twists…. Any other fixes out there ?
hermes
Greece
I have the same problem. Only when closed and driving over uneven pavement. If the sun roof is either in vent mode or partially-all the way open, no noise
BowDown
Frisco TX
It's in the sunroof frame, when I sprayed the lube in the channel, my noise went away about a day later
Chlorum
It works!
I've spayed a silicon grease twice and the rattle has finally gone 😝
Thank you guys! 👍
PS. 2019 RAM 1500 Limited
jlaner0408
Are you saying the outside frame where the sunroof butts up to the actual metal of the roof?
Mine is doing this and driving me insane. Along with the leaky back window. And the cracked manifolds. Haha
BowDown
Frisco TX
I believe so, I'd have to go out and look at it a again but I believe that's what I did because I remember the straw popping out of the channel and getting oil on the paint.
In responding to this thread it reminds me that I've still not heard that noise again since my initial post on the topic
Edit. Yes, the outside edge, all the way around the sunroof
jlaner0408
Awesome- I'll have to give this a go. I only notice it in the winter but it drives me absolutely nuts
Fernan0911
Hello.
Where did you exactly sprayed?
Between the two pieces of glass or around were the seal joins the metal?
any picture would be very helpful. I have this issue whit my brand new Backcountry.
Fernan0911
Its like the moving part is loose.
Like there is not enough tension or pull to keep it from rattling
