I found that all of the 5th gen Rams had a significantly better ride than the competition - F150, Silverado, Tundra. Not even close in fact. The Limited we drove (borrowed for several days) had improved ability to recover from multiple disturbances, but it was subtle, relative to the regular suspension. To me, the biggest advantage of the air suspension is the ability to keep the truck level if you are regularly towing. The downside of air suspension is that, common to many of the German sedans that use a similar system, typical suspension freshening in the 75k-125k range will be several order of magnitudes higher than a standard set up. That is only a concern if the money is material to you and if you keep the truck that long.
If you are concerned about pavement where you live, another thing to keep in mind is wheel diameter. The larger the wheel, the smaller the tire sidewalk and this will cause a deterioration in ride quality. My truck has 20s and while they look gorgeous, from a ride perspective I have no doubt a smaller wheel would improve it. Some of the limiteds have optional wheel sizes up to la 22 IIRC. I would avoid that size and stick with the smaller standard wheel. In my judgment, wheel size and sidewall cushion play a greater role in what you perceive in the cabin because by definition a suspension can only react to what is transmitted and if you lessen what is transmitted at the wheel, you will improve the ride.
Good luck, HTH.
