Speedometer/Cruise control discrepancy
mick243
My speedo seems to agree with gps speed. If I set the cruise control there is a difference between the set speed and the actual speed, EG, if I set the cruise to 100, the actual speed reported on the speedo is 103.
Is it possible/does anyone know how to adjust or correct this?
I have noticed that if I use cruise to increase my speed by more that a couple mph then the truck overshoots the target and seems to hang above the set point for a little while before dropping back down.
If I bump it up 1 or 2 mph it is fine, but if I hit it 5 or 10 mph it doesn't seem to like it.
Yes, I mean KPH.... but in this scenario I doubt the units matter - there is a 3% discrepancy between set point and delivered result.
and no, it doesnt matter if I bump it up in increments of 1 or 10, problem is the same.
If I'm doing a particular speed and hit "set" it will hold that speed (but if I'm doing 100 and hit "set" the cruise will show its set for 97). if I use the + to increase speed is when the problem occurs.
does anyone out there know how the speedo and cruise systems get their info from and how they interact, can they be calibrated?
Have you tried replacing your battery?
It's normal for cruise control to do a few mph between your set speed
If I set it at 74mph In can expect it to sit around 73-74, but scoop down to 70-69, and up to 76.
You say that if you set it at a speed it will hold the speed, but show its set at something different?
Have you changed your tire size from stock?
100kph to 103kph is only a 2mph difference, that is well within the expected set speed for any vehicle I have owned (62.13mph to 64.00mph). Setting crise control to 62-63 (it's a fraction of the mph so if I round up setting 100KPH is like setting 62-63MPH, if the truck goes 103kph that's the same as 64mph, very close.
its a brand new truck - about 5 weeks old, everything as from the factory (except rhd conversion by ram australia, and I added wheel flares) so I'd really like to think the battery isnt toast already....
and around here there are some places where that discrepancy will cost your license, some places will book you for as little as 1KPH over the posted limit, and the vehicle traveling faster than indicated is a defectable offence.
Sounds like you shouldn't be using cruise control if you expect it to never go over the set limit and you will lose your license for going 1 KPH over.
kinda true..... but then why buy a truck with a feature that's not useable......
and yes, the biggest issue really is our doucheknucke revenue raising politicians - but there is no hope of changing them, so I asked about the possibility of calibrating the system I have.....
You can't expect any cruise control system to stay at the set limit 100% of the time.
If you are concerned about going 1 KPH over the set limit which is a fraction of a mph its unrealistic.
You should be setting it way under, or not using it.
I don't know of any calibration. It pulls it from the same system...
I have the same problem on my 2019. Dealer said its normal.which is BS, both other rebels my friends have if you set the cruise to 100 the speedo says 100.
I have even adjusted tire size ratio, no difference 3% like u said.
Hi Mick, was just googling the c
Hi Mick how ru mate?
Im from sydney Australia. Hubby picked up his new bighorn last week and same problem. Dealer told us that the speedo calculates spped from wheels whereas cruise control picks up from gps. Apparently there nothing you can do. I believe when you are paying $100k plus for a vehicle thats just not good enough. I also think its a safety issue as people may not realise they are going over the speed limit. Im going to try to make complaints higher up as RAM needs to fix this.
I mean you can complain to Ram, but as far as I know you bought it from a reseller, not Ram. Ram doesn't manufacture trucks for Australia so a private company buys Ram's, then rips all the guts out and reassemble it (it's actually pretty cool to watch what they do) You are also paying a large importer fee, a big horn is worth half of what you pay even after currency conversions, but I know your options are limited over there.
I set my trucks speed using gps on my phone, and cruise control matches that speed.
Cruise control speed is not measured by the gps, some of the Ram's don't even have gps, they just don't know what to do so that's why they told you that.
I don't know its just ****. I really can't believe that such a thing will be tolerated by the government. I will just have to research and find out which tree I need to bark up 😉
I just bought a new 1500 Bighorn in NSW. My speedo and cruise are out by exactly 4km an hour at 100 as well. My dealer just said he’d look into it and never got back to me.
It’s extremely annoying that you have two different speed readings at the same time.
Surely if it’s common on all Australian Rams they have to come up with a solution?
My 2019 is very similar,
the analog speedometer differs from all the digital values.
Mine is not much at 60 on the digital indicators the analog speedometer will indicate a bit over 62. Per my phone's gps the analog is the more accurate.
Setting the cruise at an indicated 55 mph the analog speedometer will be at a stead 56-57 mph.
Mine is not in Australia.
Seems if cruise control runs off GPS, it is more ticket reistenat than the speedometer running off tire rotation. Agree they really should match, but shouldn't setting cruise to the speed limit be at least a defense in court? I know going to court is also a pain, but citizens should fight against tickets based on such minor infractions.
While there are some hard speed limits in the US, such as school zones in Tennessee (not only is it zero tolerance, it is reckless driving which is worse than simple speeding). For almost everywhere else, "reasonable and prudent" is our standard. Nice sunny dry clear day with no traffic on a straight stretch of road posted at 45 (curves maybe earlier or later), 50 will not result in a ticket in that stretch. Add traffic, rain, poor visibility, 35 may result in a ticket. Actually more sane than an absolute number even if somewhat subjective.
We also have white signs (posted limit) and yellow signs (a lower recommended speed for perhaps a curve). Barring safety factors, the yellow signs do not carry the same weight (no speeding ticket) if negotiated safely but it is an area where enforcement of the white sign carries more weight than that nice clear sunny straight empty stretch of road.
My last interaction with law enforcement over speed resulted in a warning, not a ticket. The office pulled me over due to a headlight out. In the daytime, on a clear day. We also have primary and secondary infractions. Without the speed (primary infraction), he could not stop me for the light (secondary). With the speed, he could stop and cite me for both. I thanked him for letting me know about the light and apooligized for my inattention to the speedometer, was just going with the flow of traffic.
Are Aussie cops really that strict? Ours are generally human if treated with courtesy and respect.
I don't think anyone is complaining about police being tolerant of 1 km/h. They are saying the cruise setting doesn't match the actual speed and it is annoying. Mine is a dead balls match FYI. And it does a decent job maintaining up and down hills. I would be annoyed also if mine did that.
