MateoQueFeo
Does everyone just fill their tanks all the way?
And how low do you let your tank get before you fill up again?
Yep.Does everyone just fill their tanks all the way?
Two jokers in every deck, right?
2 33 gallon tanks?when gas prices are on the rise I gas up when it gets below 3/4. when gas is on the down i go to a 1/4
Level 2, 33 gallon tank.2 33 gallon tanks?
Yes please.2 33 gallon tanks?
I hate to admit, but you've almost described me. As my Frontier sat 30min ago:I prefer to fill mine until the pump clicks. Then another 5 tries and 5 clicks. I don't stop until I can physically see gasoline running down the side of my truck.
On the empty side, I go until the engine dies. Then let it rest for a few minutes, and try again to see if there are a few more miles I can squeeze out of it before it dies again.
How full do you fill with gas?
You should do the opposite.when gas prices are on the rise I gas up when it gets below 3/4. when gas is on the down i go to a 1/4
I'm actually considering this. I'm picking up my 33-gal EcoDiesel, next weekend. I'm probably going to swap out my 18-gal marine tank from the Frontier and put it in the Ram. I just need to clean out any residue left from the gasoline, since I'm switching to Diesel.2 33 gallon tanks?
I fill until it stops, Then to the next $.50 higher.
Once I get my AUX Fuel Tank installed, That will give me 105 Gal on Board with the Stock 33 Gal Tank.
With the EcoDisel and the GDE Trans Tune that should get me Coast to Coast with only Pee Breaks.
Unless I install a Pilot Relief Tube! I also have a Comma3 in the truck to take over the mundane driving tasks.
Malodave
