Start of 2022 Production.
testcrewman
Texas
Interesting. You didn't spec it? Maybe they figured everyone else in LA had got one, so you should too! 😂
I did have it on my build and it's on my build sheet. Not complaining that they didn't charge me, just want to make sure I have it. When I pick it up, is there an easy way to tell? I'm assuming my miles to empty will be quite a bit more than with a 26 gallon.
KWKSLVR
Birmingham, AL
If it's on your build sheet and window sticker it's there. Probably save to say that squeezing 30 gallons of gas in at empty tells you what you have.
Duckfan1967
Camas, WA
Got an email from RAM to expect my truck at Mark Dodge the weeks of 3/22/2022, that would be 5 weeks from ordering! Not holding my breath though, could be longer with transportation.
Clemzhemi
jmt8706
Michigan
When I fill up, my DTE has been pretty consistent with 570-576 miles to empty. I have the 33 gal tank.
GR1MREAPER
have a link?
or some proof.
Just ordered a truck and tryed adding the 33 gallon tank as an option and the dealer told me about the recent change because it kept voiding the option and saying 0 when trying to add it with the 6’ 4 box.
GR1MREAPER
What are you trying to show here? If you order with the 6’ 4 box as of last week it comes with that gas tank. The dealer (granger motors) called ram and double checked because it would let them add it,
It kept saying 0 dollars. So not sure when that changed but that is what the dealer and ram said before I ordered my truck because I want that option. So if your ordering a truck with the longer bed ask before you order to double check but that is what ive been told by my dealer and ram.
SnowBlaZR2
Fuel Economy Champion
FL
It kept saying 0 dollars. So not sure when that changed but that is what the dealer and ram said before I ordered my truck because I want that option. So if your ordering a truck with the linger bed ask before you order to double check but that is wht ive been told by my dealer and ram.
You're correct.
Here's a window sticker from 17 FEB:
6'4" bed, 33 gallon tank, NO CHARGE
