2022 RAM sport is not fitting in 18 X 19 garage
So as others mentioned previously park on a diagonal.?
That's assuming the truck is about 7 ft wide and 19.5 ft long , == about 21ft from one corner to the opposite corner of the truck
Your garage should have about 26ft from corner to corner. Good ol' Pythagorean Theorem at work
There, problem solved. just explain to your significant other why they can't park in the garage and taking a different approach to parking and getting out of the garage may be a 'new normal' for you
No two ways about....yer screwed. This is with the crew and the 5.7. You only gain an inch with the 6.4 quad (sorry....I like to rule things out mathematically if not practically ;))
You're describing something different from the other post but it still wouldnt work, the other corners youre not measuring to would be the ones in conflict if you aligned the diagonal on the truck with the diagonal of the garage.
Because of my tight garage I went with a quad cab instead of a crew cab. I use a tennis ball on a string when pulling in.
My garage door opening, for some reason, is a mere 76" tall. The last 3 vehicles I've had won't fit in there ha. They live in the driveway. The ol lady's car fits, and so does the sxs (barely). I've wanted to extend a carport for years, but the Mrs. isn't sold on it.
Need to put the foot down. "Your car is in the garage, mine will be under the new car port".
It only doesn't fit once...if you pull in fast enough. :)
