jus
- Dec 6, 2020
Hi all,
Just got a 2019 Ram 1500 Longhorn, air ride, front level (daystar spacers + links), 20” factory rims, with Cooper Discoverer A/T3 tires in LT305/55R20.
I’m used to SUVs, which ride this road fine. But I’m finding the truck is skipping, hopping and sliding at the back on the corrugations, ruts and potholes on this gravel road (say at 50mph).
I aired down to 30psi rear and 33psi front and that made quite an improvement, but I’m still finding the rear to be a bit loose and it’s frankly unsettling compared to SUV driving around here. I’m having to reduce my speed quite a bit comparatively to get comfortable.
Is the problem maybe tire size? Too wide? Or pressures?
Also switched to 4WD High and that helped a little.
