2inch Level With 35's?
jneto9508
just want to make sure 35's fit with level kit ? not doing UCA. wheel is 18x9 -12 want to go with 35 12.5
looking to do the same wheel setup soon but shooting for 2.5 in the front and 1.5 in the back. from everything I've read they will fit with 2 up front. triming of the mud flap is usually required
Just read a post that someone fit 35X12.5 on stock Rebel wheels without any rubbing. Stock coils.
Tires in the garage and wheels coming in on Tuesday. I’ll post picks when installed.
2inch front lift with stock UCA
I’m running 285/65r20 (34.6”x11.2”) and they rub sometimes at full lock in reverse
I’ll end up removing the mud guards and might to to trim the metal tap that holds the guards as well
Looks good. Noticed you removed the mud flaps..
Here’s how she looks with the rear level installed
can we see some side shots when you get a chance? and some to see how far the tires poke out? i have a red rebel as well so this post is perfect. truck looks awsome.
