What is your MPG and setup?
jbsbama
I’m posting this because I’m getting pretty horrible MPG for both city and highway. Up to about 2K miles my city was 9 mpg and highway was 13 mpg. Now at 2,300 miles my city driving is currently 10 mpg and my highway is around 14 mpg.
Setup:
2020 Ram 1500 Limited
No lift yet
5.7L 3.92
Hostile Alpha 22x10 -25 Offset
Nitto Ridge Grappler LT285/50R22
Mopar Performance Cat-back
Mopar Performance CAI
Pedal Commander PC78
My stock 2010 Laramie got around 13 city and 17 highway.
Mine is a B.D.S 4” lift paired with 35x12.50r20 tires and I’m averaging 9 mpg....
I usually get about 14.5-15.5 city and I just got 17.5 almost 18 for highway for a 715 mile trip. I did go through mountains so that drastically decreased my mpg.
I have a 2019 Bighorn 5.7, 2 inch level with 305/55/20 ridge grapplers. I also took off the Air dam and front lower valence. I also have a S&B cold air intake.
Sent from my SM-N976V using Tapatalk
2020 Rebel
2" front spacer
1" rear
Level 8 MK6 18x9 0 offset
275/70R18 Goodyear Duratracs
PC78
Drop in air filter
After 9k miles I am at 14 city, 17.5 highway at 75mph. Slow that down to 60-65, and I regularly see 18+ on the highway.
Oh I guess I should add I have 3.92 gears, the Mopar cai and Fuel wheels.
Stock 2020 5.7 bighorn with 3.92s w/ 7500 miles. I typically get 19-20 highway at 70 mph. I have got 21.4 over a full tank before at 70 mph. Combined/city is all over the place but usually no less then 15.
Stock 2020 5.7 bighorn ORP with 3.92s w/ 1800 miles eTorque. 17.7 Blended. 20+ highway under 75 and under 60 mph on back roads seeing 22 to nearly 23 this weekend on a 90 mile jaunt.
So everybody is getting sticker or close to it. Why is mine so low I wonder?
I rarely drive highway... back country roads that a hilly. Averaging on the dash at 16 per gallon.
I have a 2020 Big Horn, 3.21 in the rear, 5.7 hemi (no eTorque). Crew cab, short bed.
Sent from my SM-N975U1 using Tapatalk
Shoot, I’m not even getting close to what’s advertised lol...
Likely contributers...
What's your load rating on the door jamb sticker? Limited editions can weigh quite a bit, not uncommon to have 700-800 lbs of options over other trims. Also, what is your tire pressure at?
I’ve added quite a bit of weight to mine between all my extra stuff.
15-16 city, 19-20 highway, as advertised. 2019 Bighorn, all stock for now. 275/55R20s running Goodyear Wrangler A/T Adventures with Kevlar. I tend to not go over 75mph
2020 laramie sport off road package stock. 17-18 ave, 15.5-16 town. 22 on road at 60 no wind. Probably closer to 19 at 70mph. Had a 15mph tailwind the other day. 60 mph roads and got 25.5 after 200 miles including small town slow downs.
Bone stock on mine (OEM tires and no lift). 3.21.
Purchased new in June 2018, and I have ~14,800 miles.
City - 8.0-10.0 MPG (which is normal for me. I have a stupid short commute). If I happen to drive freeways for a couple of days, it goes up a tad, but not much.
FWY - ~19.0-19.8 @ 70 MPH.
2020 Limited. Stock except for a lot of minor cosmetic things and tires/rims. The things below affect my MPG.
3.92, LSD, pretty much every option except MFT.
UPR catch can (very slight + because no oil in cylinders)
18" Rebel rims w/ 275-65-18 Falken Wildpeak A/T tires (moderate - because these tires are a bit heavier than factory, and are A/T tread, despite being same size as factory)
Pedal Commander (moderate - because now I go zoom-zoom up to speed rather than just one regular zoom)
I'm currently getting high 13s in city. 20 minute commute to work, when I go into the office (currently doing 95% WFH due to COVID).
Before the Pedal Commander and rim/tire change, I was getting mid-high 14s. Less than 500 miles on her so far, no long highway trips yet to give a good highway MPG.
19 Laramie ORP 18k on clock. 2”level, carbon delete w/ drop in, B2fab muffler swap, 180 stat. Running 93 fuel. Everything else stock. Mostly all mix driving with little fun I’m at 17-18 mpg with canceling mds every drive.
Was more 18-19 at times higher when continuously using mds. Contribute that to the back roads and 40-55 pretty constant with little traffic. Seems to be the sweet spot for our trucks.
See my Fuelly in my signature.
2019 Ram 1500 4x4 ORP
3.21
eTorque
Stock tires/wheels for now (going to change to Rebel wheels and their size tires)
~36300 miles
2019 RAM 1500 4 X 4 CC, Bighorn. Mostly stock. 5.7 Hemi, No E-torque, just got an AEM dry air filter in box. Also have Full Mopar Fiberglass Bed Cover.
Got 275-65-18 Falken Wildpeak A/T tires on stock rims, no lift.
I get 13-18 in town, and 17-22 on Hwy,. I run 89 gas. FWIW, I got 14-18 in town and 21-23 MPG on Hwy with stock tires. I am happy to lose 1-1.5 mpg on good tires instead of those inflated OEM Balloons.
