2020 6 inch lifts...Anyone yet?
ehk49
My 2020 Bighorn is at the shop today and tomorrow for a 6" Zone install. I will post some pics later this week and let you know what the shop has to say about the install.
ehk49
Lift finally got installed. Wheels are Hostile Alphas and tires are Nitto Ridge Graps 295/65/20. This is not a great picture but there's a dumpster taking up most of my driveway right now. I put about 30 miles on it after picking it up, and I would say the ride quality is somewhat stiffer than stock, but definitely not harsh.
jasnak
^^^. Which part of NJ are you located in ?
Just got home with mine. 2019 bds 6 inch on a 2020 rebel ecodiesel. 35x12.5x22. -19 offset fuel contras. Everything bolted right up with no issues. Rides like factory. Factory rims and tires in the back of truck still
ehk49
Warren County. OK4WD did my install. Great place to deal with.
aimlowrobin
Looks good
aimlowrobin
Looks good! I'm amazed at the ride results of the bds. I've had several different lifts in the past, including Mopar with fox coils, but this one is the only one I can say rides like stock.
justinbeez
I wonder if its safe to say the 2019 BDS kits fit on the 2020s? You, aimlowrobin, and ehk49 all have the 6". Does anyone know if the 4" uses the same crossmember? Wanting to get the 4" BDS for my 2020 BTS edition.
jasnak
It will be the same. Nothing will be different for the crossmember. Be the same a 6 inch.
Hobz62
Installed my BDS 6 in lift on Tuesday.
ElJoe
I had emailed BDS telling them they didn't have any options, other than the 2" coilovers, for the 2020 non air ride 1500s. So i asked if I could just order the 2019 kit. Full disclosure, I was inquiring about the 4" lift. Not 6" lift. They replied saying, "The 2020 kit will be out shortly- the 2019 kit won’t work on it. We’re probably a month out on the kit for your truck." This was about 1.5 weeks ago. Also, this might be a dumb question, but on the picture of their kits. 4in or 6in, it doesn't show a replacement pair of front shocks, why?
justinbeez
Im assuming they reuse the stock fronts as they also use new spindles
Hobz62
Usually you can upgrade kits from the spacers to coilovers for additional $. Odds are FOX doesn't have them released yet.
Haroderon
OK4WD did a pretty nice photo shoot of my truck for their online garage. Much better pics than what I shared here:
Truck looks amazing! Just to clarify you have a 2020 model and put the 2019 Zone 6" on right? I really want to order mine but they still aren't "verified" to fit on their website. Thanks!
