FOG LIGHT LED TO OEM
iamremi
I have a 2019 ram longhorn edition.
Came stock with all halogen lights.
I've swapped out the tail lights and headlights (used adapter) for the LED version.
I can't however get the LED foglights to work when I plug them in. The plugs are identical. I assumed it would just be plug and play, similar to the tail lights.
Can anyone point me in the right direction of what I need to do in order to get the LEDs to work?
FM45
MA
On the premium LED Fogs... reverse the wires... same plug but wires need to be switched...
Screenshot_2020-05-20 Mopar Connection Repair Kit.png Screenshot_2020-05-20 Mopar Connection Repair Kit.png
-=FM45=-
FM45
MA
per the wiring ... pin 1 is ground, pin 2 is feed for the leds... on the non leds, pin 1 is feed and pin 2 is ground...
-=FM45=-
Kidder
DFW, TX
Do you mean Bighorn? The Longhorn should have LEDs standard. I'm just curious.
iamremi
-=FM45=-
Got it. Will give it a try now. Thank you
Bruins5515
Did you replace your taillights with OEM LED? And we’re they just plug and play or did you need an adapter, looking to do this to my big horn.
