RamSco
- Apr 18, 2019
I'm about to take delivery on a Laramie with the ORP non-air ride. When I ordered it, both ProComp and Rough Country advertised their 6" kits fit all except Rebel and TRX. Now they are warning against installing their kits on ORP equipped trucks due to stressed ball joints. I'm confused why.
I understand ORP has a factory 1" lift and adding 6" would theoretically be 7" of lift from the non-ORP base suspension. What I don't understand is how that is so bad for ball joints? (please keep reading before judging
FCA, given it gave the ORP a 1"lift in the first place, theoretically calculated the angles to be ok on stock UCA's and ball joints. The 6" bracket kits drop everything down to stay within the factory spec relative to angles. In the end, it should be stanced 1" higher than a non-ORP with the same kit? If the answer to my question is "yes", than FCA engineers theoretically allowed the extra 1" within their spec of the ORP? So it shouldn't necessarily be more stressful to the UCA's and Ball Joints? (notice I have more theories and questions than answers)
I'm seeking expert advise on this. I'm going to do one of the following: 1) install the lift right over the top of ORP components for 7" total lift from non-ORP 2) swap out ORP struts and springs with non-ORP while installing the lift and stay at 6" 3) walk away from a $1,000 non refundable deposit becase ORP won't accept a lift and I'm not buying a truck that I cannot lift.
Need a sanity check please.
