Splash Guards
Rayzram
Not really impressed with the fit. Ram could do better. Horrible lines in regard to tire coverage and not flat to the ground. Maybe im just super picky, but they should come down in line with the tire and sit flat across the bottom.20181014_010204.jpg20181014_010225.jpg
That looks terrible from the picture. I ordered the WeatherTech flaps on Thursday. I’m hoping they are much better than my WT floor mats.
Not really impressed with the fit. Ram could do better. Horrible lines in regard to tire coverage and not flat to the ground. Maybe im just super picky, but they should come down in line with the tire and sit flat across the bottom.View attachment 6301View attachment 6300
the problem i see with the mopar flaps is they have a "pocket" area at the bottom. this area will collect debris and snow. i could seethes being one of those areas where a pressure washer will spit whatever it collects right back at you when washing. GATORBACK or WEATHERTECH for me when my truck arrives.(y)
Yea, I don't like how the mopar flaps wrap so far over the paint work. I guess if you have the flares it would not matter but that area has potential to collect water and dirt and eventually rust.
Has anyone had issues with the fronts rubbing I just installed them on my rebel and the fronts are rubbing bad
I'll get some photos of my gatorback mudflaps installed tomorrow.
Stock tires? Mine clear but not by a ton i assure you running factory 20's
I'll try and get some pictures later I have factory 18's and I believe 33 inch tires I'm going to try a heat gun later too to mold them back it almost looks like they curve in, I didn't have this problem on my 16 rebel maybe I got a bad mold but who knows:unsure:
A little dirty, but you get the gist. These are very solid rubber,with a powdered black steel coat plate facing away from tire (rubber facing tire), and feel great. I like the look. I'm happy with them. Only thing I might do is carefully spray black undercoating on the stainless steel washers. 20181016_093228.jpg20181016_093257.jpg
Weathertech fit very well
They do curve in and it drives me nuts. Horrible fit in every aspect.
Yeah I tried a heat gun to make then flat and it's not rubbing as bad anymore but I think I'm just going to order weather techs for the from and give up on the mopar fronts and keep the rears
I wished I read your post and viewed these pics before I ordered the Mopar Splash Guards...I agree with you! Put the guards on yesterday and removing them today! Now to check out Wathertech...
