The dreaded leaking and cracked rear window frame
frisby5
If my rear window starts leaking, I'm not going to d!ck around with the dealer, just to have another defective rear window installed. I'll buy a solid rear window and have my local glass shop install it. $300-400 out of pocket and the problem is solved.
Solid rear window! If your keeping the truck get a solid rear window so you dont have to worry about it. Thats my truck at the dealer when i was buying.
Shadowsnkx
After putting a bead of silicone on my rear window frame, I still had a slight leak. While working on my audio system I noticed the rear wall vents were filthy with dirt and had water spots. I popped it out and the dinky seal around the vent has been covered with silicone. After letting it dry for a few, I have been through several rainstorms but no more leaks.
Stony0604
100% agree that it's an outside party doing the glasswork. Part of it is I just don't want to lose. hahaha. I agree the $467 probably isn't worth the hassle but I'll see what the GM has to say.
Doesn't hurt to ask the GM. I just had to drop it off again yesterday, as the glass was on back order. One day in and out, but they didn't charge me a dime, and it too was subbed out to the glass company.
rkjunior
Update on my truck, which is a 2019 Rebel with 80K. FCA is covering all materials for the repair -- the back replacement window and the RF hub. My servicing dealer won't give me a full credit on labor, which is normally around $800 -- they settled on $467. Apparently "it's a third party doing the glass replacement and we're losing money on it". My issue is FCA is acknowledging there is an issue enough to cover $2000+ in parts but yet not the labor? It seems like the service manager is doing everything they can so I'm attempting to contact the GM of the dealer as a next step.
Anyone ever successfully take them to small claims on something like this? I feel like with the support of the TSB, which doesn't specify why my truck is NOT covered - it could be a winnable judgement in my favor. It's only $467 but the principle behind it since no one can tell me why it's not covered even though it meets all the criteria.
Update: Got a call from the Ram Cares rep randomly today and long story short, she basically said she was fighting for my case behind the scenes and I now only have to pay for $100. Not sure where that number came from but I wasn't about to complain. Apparently the glass has come in- just pending a schedule from the installer at this point.
kferguson
I am having the same issue with my 2019 Ram 1500 Laramie. I have the two identical cracks in the window frame that everyone else has. I don't know how long they were there because the water leaks behind the seat and runs down and settles under the seat on the passenger side. I didn't know until I lifted the seat to get something out and saw a ton of mold and felt the soaked carpet. I called the dealership and they said to bring it in so they can test to see where water is coming in. So I took it in (the drive is an hour away) and they said the warranty extension doesn't cover this model and only covers the third brake light. They said they'll run the diagnostics to see where it's coming in. Then they printed out a document stating the diagnostics will cost $433, which was NEVER mentioned on the phone. They said to call FCA Customer Care. I called and they were completely useless and told me there is nothing they can do. I don't understand why some models have the warranty extension and some don't, even though they ALL have the exact same issue with the window. Now I'm stuck paying $433 for diagnostics, which will go towards a new window, but I have no guarantee that the new window won't do the exact same thing this one did. I'm SO frustrated that they won't step up and do the right thing. I don't want to keep replacing the same back window over and over again for something that isn't my fault.
mikeru82
5thGenRams Supporter
The Palouse
I am having the same issue with my 2015 Ram 1500 Laramie. I have the two identical cracks in the window frame that everyone else has. I don't know how long they were there because the water leaks behind the seat and runs down and settles under the seat on the passenger side. I didn't know until I lifted the seat to get something out and saw a ton of mold and felt the soaked carpet. I called the dealership and they said to bring it in so they can test to see where water is coming in. So I took it in (the drive is an hour away) and they said the warranty extension doesn't cover this model and only covers the third brake light. They said they'll run the diagnostics to see where it's coming in. Then they printed out a document stating the diagnostics will cost $433, which was NEVER mentioned on the phone. They said to call FCA Customer Care. I called and they were completely useless and told me there is nothing they can do. I don't understand why some models have the warranty extension and some don't, even though they ALL have the exact same issue with the window. Now I'm stuck paying $433 for diagnostics, which will go towards a new window, but I have no guarantee that the new window won't do the exact same thing this one did. I'm SO frustrated that they won't step up and do the right thing. I don't want to keep replacing the same back window over and over again for something that isn't my fault.
The warranty extension is for some 2019 thru 2021 5th gen (DT) models. Your 2015 is a 4th gen (DS). It shouldn't be surprising your truck isn't covered under this warranty extension.
mikeru82
The Palouse
It was a typo. I totally didn't mean to type 2015. I meant 2019. Thank you!
Lots of us are finding out our trucks aren't covered under this TSB, with no explanation as to why. Same cracks as in the pics but the warranty extension doesn't apply. Frustrating for sure.
theblet
It’s bs for sure
DaveRebel
What dealer
They will replace it. They aren't going to test if it is leaking. Just say it is and get it fixed. Had mine fixed. They came out and took pics and sent it in to FCA and it was approved and replaced. Easy.
What dealer did you go to?
