RLee276
- Mar 14, 2022
Mine did the same thing as his and even a little more. Every time I would change setting by pressing the set + or minus. And I did enable light L’s in motion. But I have not remapped any buttons and and I also didn’t hold the left arrow.Also, you should have had to hold down the left arrow and then the cruise cancel button to bring up the menu, and then the cruise up/down to scroll through menu to get to light show to turn on. , unless you enabled shortcuts for the lightshow. But it doesn't sound like that would be the case if you don't care about the lightshow.
Sounds like previous owner must have enabled lightshow in motion, and shortcuts for the lightshow as well
And same happens when I do try to adjust tazer settings. When holding the left arrow and if I touch set plus or minus pulsar chafes power and tazer flakes out and does something weird the. Gets stuck on updating screen. Then I have to toggle out of audio screen the. Back.
