I replaced the stock halogens with LED from underground lightning. The headlights (low beams only) are great. Bright, adjusted to not blind anyone. Great upgrade from stock. The fogs are the same with the exception on the drivers side. Seems to flicker and dim and then work great. Sent it back to underground lighting and Danny was amazing in checking it for over 8 hrs on the bench. He said the light is working no issues. While he had the light I swapped the fogs and the drivers side acted up the same way. Danny advised to try a anti flicker module or…..this is his email copied and pasted below.
“ We can try the anti flicker module. Its sounds like your oem plug is dropping voltage randomly. Which is not normal and i don't know why. If it's dropping to 9v the anti flicker should solve this. If it's below you need to find out why. Can be a bad ground or computer program the dealer would have to get involved. So with a halogen you won't see the power drop cause flicker it will go dimmer and will cause the bulbs to burn out fast.”
Has anyone had this issue? Not sure what to try next, the anti flicker module did not help.
