LASFIT LED’s
GrinchKing05
I also converted the halogens in my 2019 Bighorn to lasfit LEDs. Low/high beams, fog, 3rd light above window and taillights. I do get an occasional flickering when at a stop, I also have the e-torque (V6) so I’m wondering if that’s causing it. Super bright lights and may need some minor adjustments bringing the low beams down a bit. Everyone thinks I have my brights on all the time. I did have Lasfit mail CANBUS adaptors. I covered S&H but refused to pay for the adaptors themselves and Lasfit agreed after several emails. I have yet to install the adaptors due to time, if I do I’ll post here.
There’s a guy on this forum who absolutely hates Lasfits bc they aren’t the “correct” light. I’m sure he’ll post here soon.
JamRam
i literally just completed the entire LASFIT led bulb ugprades today! I have a 2020 Big Horn.
I did the full interior as well as the reverse & brake lights, and the 3rd brake (cab mounted) light - not a single problem and everything was plug and play.
For what it is worth, I also did the LED bulbs in the low/hi beam & fog lights, however those I used "sealight" off of amazon and those have also been plug and play.
Do you have a link to the Sealight bulbs that you use?
I want to change out all 6 of my front lights, but the bulbs seem to only come in 4-packs. I want to make sure I buy the right ones.
jeffjcalweb
pgers22
I used Lasfit for the 3rd brake light and cargo lights. They have been in for about 2 weeks. There's not been one single issue. All interior lights are also Lasfit LED's.
can you tell me what part numbers you ordered? I will try them then. Want to make sure I get the correct info. What did you update for the interior? My last rebel had a sunroof and this new one I opted to not get one so I need a replacement for the main light and possibly the map lights too. Thanks
jeffjcalweb
If you go to Lasfit website they have a very specific and detailed list of bulbs. Pick your model, year etc. They will give you a specific list - including a 'bundle' that will give you all the lights you need for the interior etc.
Lungs414
Which LASFIT for the white lights in the third brake light, 2020 Laramie.
One of my 2 has a mind of its own switched to other side same thing. Expensive for a little over a year for bulbs that aren't used too often.
Thanks
JAHarwell
I did the fogs, lows (H11), and highs (9005). Stock bulbs were halogen (Bighorn).
There is a hint of an unsteady beam for all three (not bad, wouldn't call it a flicker, just seems like power modulates) at idle. When driving I did not notice it at all.
Trying the canbus adapters on the lows as that's what their customer service rep recommended.
Will update when it gets here.
Good news is they are a huge improvement over stock. 6000K looks pure white and high end. If I can't solve the modulation issue, I'll probably switch to Sylvania silverstar ultras for the lows. Anybody use those?
Experiencing the exact same thing. Did the canbus help?
dawenger85
Newburg, PA
if you get the LEDS with canbus error free they wont flicker and you wont need a canbus module. aka plug and play with the stock halogens
c3k
I tried that with my son's Tradesman. I ended up with 5 codes: B16D7; B16DF; B16AF; B16B3; B16B7.
Those were for rear brakes, rear turn, and backup lights. So, no bueno in my experience. I sent emails back and forth with lasfit, and even bought new replacements (my pocket), and still no good.
Biga
Cincinnati
I installed the diode dynamics in my 2025, the same ones I had in my 2019, and everything seems to be okay on the truck. Now the truck was parked right under my garage door opener and the garage door opened on it's own then started to smoke a few hours after installing the bulbs. Not sure if they caused some kind of interference with the opener or it is unrelated.
