Interior lights (oem to led)
Cheebie
Twin Cities
I am sure this has been covered but I cannot find a definitive thread.
I would like to change all of my interior oem bulbs to nice and bright led ones. I have looked on many websites and have cam up with few options.
Has anyone swapped out all of them?
Map lights, footwell, and rear dome with no issues?
My truck is a 2021 1500 with led headlights, tail lights and license plate lights.
Thank you
Nickv1214
Thank you
I did all of mine .
Haven’t had any issues yet , and they are very bright
Nickv1214
He has the direct links under the video in the description
kdoublep
USA
I did all mine with Lasfit. Just did footwells today with ice blue lasfit. Everything else I did white.
soSincerious
lil Rhody
would be cool to have a "switchback" type ...
one click, soft amber moodlight
2 clicks, full white LED
Cheebie
Twin Cities
Awesome!!! Thanks for the replys
That blue looks pretty cool, and yes, color switching ones would be awesome as well
kdoublep
USA
Yes or Amazon prime if you got it. You'll have to compare the two because Lasfit does have a few discounts right now. I just went with Prime.
Keezer
Southern CA
Thank you
What trim? Big Horn no problem, 2020, 21 Laramie on up, at least the foot well wont work, nothing like the Big Horn.
Simplman
I also switched all the interior lights to the Lasfit bulbs. It made a huge difference. I bought a complete kit off of eBay with all the exterior lights as well. Love them, headlights are pretty damn bright. If you do the exterior as well good luck with the third brake light, it’s hit or miss if it messes with your push button start. I had to go back to oem for the third brake light. Good luck with the switch!
Amerinamese
I bought these from Amazon for $20. Changed out all my interior lights and my 2x cargo lights.
Cheebie
Twin Cities
I contacted lasfit and they were very helpful, loaded up, pics when the get here and installed. Thanks for the lead.
Cheebie
Twin Cities
Well, as far as the footwells drivers side anyhow. It looks alot different than the 2019,2020. So I got some investigating to do on removal
U
User_34235
Guest
I too changed all interior lights (minus the footwell) to LED's and what a difference. A fellow member on here helped a LOT with advice. Lasfit bulb in the dome light was VERY loose and you will have to bend the prongs on each end some to make their bulb fit tight. The map lights scared me a little trying to pop put the entire console as the front of it is very tight in there and I was nervous that I was doing it wrong.
The video at Lasfit shows them removing the footwell liner on the passenger side to get the footwell light out, so that is my next project..
NorthStar
Texas
Assuming you have the Big Horn/Lone Star version, simply pop the white lens cover off the drivers side footwell light, Remove the bulb, replace it with an LED, reinstall the lens and you're done. My experience has been the easiest way to remove the bulb is to utilize a pair of needle nose pliers to gently pull it out or I've also utilized the fishing line method where you take a 12" piece of fishing line, create a small noose, hook it around the bulb and pull it out...unless you have skinny fingers in which case you may be able to remove the bulb with your fingers.
NorthStar
Texas
Completely different set up then the 2020
Ah, I see above where yours is the 2021 Ram Big Horn 1500 Built to Serve Edition. Correct me if I'm wrong but you have the LED package on the built to serve thus you have LED headlights/taillights and the footwell lights you have are factory LED. No bulbs to replace.
