firecadet613
- Jan 30, 2018
I did that and the manual kinda pisses me off. It has a list of fuses but not a map of the locations on the box. And at 50 YO I'm too f******g old to see the tiny raised dimples that pretend to be numbers.
I'm 33 and it was a PITA to see! If i remember right, i counted from the side to find the right one.
Fire, when I removed the pannel below the steering column I found the fuse box (eternally grateful for your post) but no lid on it with the fuse layout. Ergo, no guide to which fuse is which. Using your step by step will work for me (thank you again) although I'm using a micro add-a-fuse connector. So, if this is a noob question please forgive. How did you know that fuse name was in that location? I can't find a schematic for that block anywhere. The owners manual lists them, but doesn't show whre those positions are in the box.
Hmmm....i thought it did. Maybe not. They should be numbered?
