eTorque Generator Replacement
GaryT
I didnt turn up anything with a search, apologies if this has been covered. Does anyone know if the 2019 5.7 eTorque generator is something that I can replace? My truck is at 87k miles, 7k past the warranty on the hybrid components, and the MGU is making some unhappy noises for the first few minutes after a start. It almost sounds like a bad idler or tensioner pulley, but I was able to isolate it to the MGU. It eventually quiets down a bit, but it never goes way. Voltage is good, no engine light, etc. I am finding new and low mile take-offs for roughly half the cost of a new generator and I would rather avoide the hassle of getting this to a dealer for service if I can.
djevox
VP of Creative Thinking
MD
You mean this? If so, then yes.
SpeedyV
Ram Connoisseur
Fort Worth, Texas
Looks like it's relatively straightforward to replace, provided dealing with the belt/tensioner is no more of a hassle than with a traditional alternator. I believe you'll be the first member to replace their MGU/BSG out of warranty, @GaryT!
GaryT
Nothing about it looks to be anything but routine, I saw a TSB somewhere about the MGU and it mentioned programming the gear ratio and that didn't make any sense to me. Apparently the water pump belt is a stretch to install type and it's a one time use deal.
GaryT
Finally got the chance to do a tear down today, and it was inconclusive. Removed the belt, spun each belt driven part, no noise, no roughness of any kind. Of course, I put it all back together and the sound is still there and clearly coming from the MGU. When I spun it by hand, it was smooth with just what I would think to be normal resistance, just slightly more than your average alternator. So. I don't know. I guess I'll run it until whatever it is fails then go from there.
GaryT
Well, after just over 3 months, I was finally able to find a new MGU (eTorque generator) and install it. This is after going through 16 different dealers, all of which showed this part in stock, only to cancel the order within a day or two. I found mine at a local dealer who ordered one for a customer in March, they didnt pick the part up, so I got lucky. They did tell me that they recieved word from Ram that they do not currently have a supplier for this part. In late August, there were 29 leaving the warehouse that were all spoken for.
Warranty isnt relevant in my situation as my truck has 88K on it. One thing to note is that the install is relatively simple, but the part will not work out of the box. Mine wasnt charging and required a dealer flash to make it work. It did make the 5 mile drive to the dealer without any issue. I couldnt find this information anywhere prior to this, so I am noting it here for anyone else having this issue. The flash was $150, the part was $1488 with tax.
TheWaterman83
Yup. Mine was replaced under warranty very early on in the global supply chain issues. Took my dealer a month to get the part. Invoice cost was a little less, $1,200 but everything has gone up since then. Sounds about right for a re-flash. I paid $120 way back when for my Jeep GC.
You're right. It's very straightforward to replace but the re-flash has to be done by a dealer.
peeceejay
My 2020 with 25k is making a whining noise that the dealer has identified as a worn MGU bearing - I'm waiting on a replacement that should be here early Jan - good to know it's a simple replacement, if I ever need to do it again
SpeedyV
Ram Connoisseur
Fort Worth, Texas
How loud / persistent is that whine? A few of us have heard something intermittently.
Octaneguy
Anaheim
I'm in the same boat with a 2020 with 24K miles and its been making the whining noise for the past several months. I took it to my dealer and they told me it needed a new alternator which of course is the MGU and of course they told me its on back order. This is a year later from the previous posts and seems nothing has changed.
RAM_Davis
Well at least you saved about $400 in gas over a traditional alternator... :)
drm82
My truck has been at the dealership since November 9th, and I was told the MGU was on back order, and at first they had an estimate of November 22nd, which then got delayed another week. Now I'm told December 18th is the ETA of the MGU. I guess we'll see. Truck is a 2019 with 56,000 kms. Canada here.
Superbirdrag
Hi folks , I have a 2019 with 200,000 kms on it . The etorque unit needs replacing. I found one off a 2023 but the dealer says the part number doesn’t match via the vin sticker on the back.i found another one that looks the same and the add has the part number the dealer said work. mine on my truck says ram on the top. The one I bought says etorque, the one I found in the ad with the proper part number, says Etorque on the top . I can’t tell the difference between the one I bought and the one in the ad. Does anyone know if these are all interchangeable or if there’s any differences between them?
Snekpete
Maryland
I believe that this is the thread that you need to read.
