Thanks for the replies.. I guess now I just gotta wait till they have something for the 2023 models... Question though, can I use these "canned" tunes for my 2023 after purchasing another license for the Diablo i3 tuner? Assuming I get an unlocked PCM.
Yes.
The license allows you to tune 1 car\truck IE vin number.
You can tune your ECM and or TCM with 1 license as it's per vin.
You can do simple stuff like disable auto start-stop and disable MDS without needing to engage gear limiter, also remote speed limiter all with "canned tunes" "parameter" changes.
Basicly you are stuck waiting until your PCM can be unlocked and or you get another one that is unlocked (make sure it's for a 2023 then you can connect and see what options there are.
Note that if you choose the "Diablo" which also is sometimes "performance" tune you will need to use 91 or 93 octane (I forget which) gas.
These trucks already recommend 89, so it's not that much big of a jump imo, and at least for me I seemed to gain mpg going to 93 (I generally only have access to 87 and 93)
