Cleaning/washing “Night Edition” Grill of 2024 Limited
vtcats
Vermont
Curios to know of any other OCD people on here that may have the black night edition grill. Did my first hand wash today to get rid of the salt and wow, my OCD keeps me at that grill over and over trying to get it clean. I sprayed it, washed it, Soaped it, rinsed it and dang. There must be a brush of some kind that gets in between all those layers of plastic. Any ideas/thoughts???
dajogejr
Soak it in soap first, the pickup any one of the dozens of detail brush kits off amazon for less than $30.
Same kind of brush I use for tires I also use for the grille on mine. Not the same brush…same kind :)
EightSixtyConcepts
5thGenRams Vendor
5thGenRams Vendor
Oh yes, mucho OCD here. CarPro makes some excellent products. I have no affiliation with them, I just get good results. What specifically are you seeing left behind after your wash?
vtcats
Vermont
The night edition front grill has a ton of “nooks and crannies” that normal washing doesn’t get to if there is dirt. The result is like many touch less car washes in areas if dirt that the spray didn’t perfectly spray a particular area. Meaning it doesn’t take off all the dirt unless something (wash mat, brush etc) is directly applied. So the result is this nice clean truck but you can see dirt still in the grill. I ordered a small brush pack that I just received the other day. Seems like this will do the trick.
