- Jul 25, 2020
If you are one of those who bought the AJT Key Fob case
Please make sure you follow this. The instructions from AJT do not include a very important part. This bit me in the *** over the weekend when I was unable to start my truck after the fob battery died. Inside the factory fob case is a RFID chip that must be transfered to the AJT case. There is no mention of this from AJT. This chip is the only way you will be able to start the truck should the fob die. I'm guessing my fob battery had just enough juice to unlock my doors, but then couldn't start it. without that chip, pushing the fob against the start/stop button doesn't do anything. I confirmed this by removing the chip from my factory fob, which required cutting the factory fob, because it's glued in. Then went to my truck, with all fobs in my house, and with just the chip pushing on the start/stop button the truck started.
Picture of the chip in factory fob case
Picture of chip removed and damaged to factory case
Picture of chip in the slot in the AJT case, I can only assume was.mesnt for the chip. Even though AJT instructions make zero mention of this
Products | ajt-design
www.ajtdesign-llc.com
