6 to 5 lug swap
Bctexascrazy1
Just curious if anyone has converted their 5th gen from 6 lug to 5 lug and what was involved. I’m wanting a certain rim for my truck and only offer in 5 lug configuration and I’m not big on doing wheel adapters or spacers. Will axles from a 4th gen swap right over or are the axles different from 4th to 5th gen?
Biga
Cincinnati
yea just to get a certain wheel would be an excessive cost. Thier are 100's of 6 lug wheel styles available, I would choose another one.
Darksteel165
Massachusetts
And thinking about resale. I would never buy a truck where the amount of lugnut is different then the oem, that's a huge red flag imo.
mikeru82
5thGenRams Supporter
The Palouse
I have no idea, but you might want to look at 4th gen forums to see if anyone has swapped to 5th gen axles to be able to use 6 lug wheels. You base your work on what they had to do for the swap. I'd think that would be a more popular swap than what you're wanting to do. Not that I've read any threads about that in any other Ram forums I visit. But it's worth looking if you're that set on those specific wheels.
Bctexascrazy1
Well not only is it a certain wheel, I also already have a set on welds in 5 lug pattern for when I go to the track. I don’t give a $hit bout resale, it’s paid off and got enough money in it as is. Y’all act like the job of doing it is like doing an engine overhaul, just got to find five lug axles and just on both the diff cover. Take the axle clamps out and pins and a slide right out. You don’t even have to mess with opinion or bearings or nothing put the cover back on and fill fluid in the France all you gotta do is have different drums, but I’m converting it from being a lifted 4 x 4 to lowered street truck. Just curious if anybody has done the swap before ?
theblet
To me it would be easier to just buy new welds for your race tires in a 6 lug. Hope you find your answers tho
Bctexascrazy1
check the spline count for starters, and you'll know.
That’s what I was curious about, was also know the length of axles are same. I checked with Mopar parts and the axles definitely have two different part numbers, but doesn’t state what the difference is. That’s why I was just curious if anybody’s had axles out of both of these. And the measurements of them I don’t have my fourth gym no more so I couldn’t pull the axle out and measure it.
silverWS6
EPTX
You'd probably have to swap calipers too. Considering that the 5th gen rotors are much bigger than the 4th gen.
Plus tho, you'd be able to run 17's so get more meat on the tires 🤷‍♂️
CHeYeNNe71
Never even thought about the brakes. :unsure:
boogielander
i dunno why would anyone do that especially when getting new wheels is a lot more easier than messing with the axles, splines, diffs.
but if you know how to do it and think it's easy... do it and report back the result?
