Turning headlight completely off on a Canadian Ram
TRXFLO
Good morning all,
I have an issue I cant figure out yet.
Over the last year, I have imported several Canadian RAM 1500's to Europe and I have made them suitable for the European roads and rules.
No big changes but mostly regarding lighting.
The trucks I imported all had a head light switch with four options ( 1- OFF, 2- parking light, 3- low beam, 4- auto).
The trucks we have now (2022 Limited and a 2022 TRX) both have a switch with 3 options (parking light, low beam and auto). (P68469535AA)
I have ordered the new switch with 4 options (P68156064AC). When I installed it (before turning the low beam DRL off with ALFAOBD) it worked like 2 - 3- 4- 1 (parking, low, auto, off)
Now I turned the low beam DRL off and when I install the new switcht, all the options result in low beam shining (except for one).
Is there a way I can use the new switch and make it work correctly using ALFAOBD?
Maybe some country/region settings?
Thanks
theblet
Did you have the option of turning off the DRLs in the trucks radio settings?
Jonas
Hello
I live in Sweden and my RAM 1500 is Canadian import and I used a tazer dt and set the truck to USA setting and moved the DRL to none in the tazer dt settings. I got the DRL setting in the uconnect interface now.
Before the DRL was in the lowbeam so no matter how I put the lightsettings, the lowbeam would come as soon as i realesed the handbrake and put the truck in drive.
