Adding Passive Entry: How-to
Ramhighflyer
Just wanted to chime in, just did the rear doors, got the wires from Jimmy, the part numbers from page 1, all pretty straight forward and exactly per the instructions in this thread, about 3 hours for the drivers side, 2.5 for the pax side…and I was not working very fast or hard….. no real issues… side note, the handle caps were NLA in my color, so I just ordered whatever color they had in stock, and swapped the little magnets into my existing caps, easy peasy, 30 second job… Also wanted to Mention Jimmy and his harness making skills.. this is something we should all be super greatfull for, to have such a super professional helping us out with this… were absolutely perfect, labeled as they should, perfect length, wrapped correctly…. Worth every damn penny of what he charges…
Pete
Quietpeen
Just wanted to chime in, just did the rear doors, got the wires from Jimmy, the part numbers from page 1, all pretty straight forward and exactly per the instructions in this thread, about 3 hours for the drivers side, 2.5 for the pax side… no real issues… side note, the handle caps were NLA in my color, so I just ordered whatever color they had in stock, and swapped the little magnets into my existing caps, easy peasy, 30 second job… Also wanted to Mention Jimmy and his harness making skills.. this is something we should all be super greatfull for, to have such a super professional helping us out with this… were absolutely perfect, labeled as they should, perfect length, wrapped correctly…. Worth every damn penny of what he charges…
Pete
I had thought the passive entry on the rear doors was over the top but i do see the benefit/want for it. do you know what post in this thread starts the process for tapping into the front doors? Many pages in this thread that I don’t want to read lol. Yes Jimmy07 is a great resource and needs to be mentioned as much as possible.
Ramhighflyer
Page 44 -45 has some good info with pictures…. The harness from Jimmy is labeled with what wires to tap into by the front seats… make sure you look at the pictures on that page on WHERE those wires sit..
Dag302
Getting ready to attempt the install on my 2021 Ram 2500 Bighorn. Vehicle came with everything including the big nav unit and surround camera. Of course no passive entry.
Question is I have read various things regarding the security bypass. Must the dash be removed for the 2021 2500’s to access? Gets confusing because there are so many tutorials on the 1500 and some on the 2500.
On a side note anyone in Northern California want to make some extra cash to install? :)
vincentw56
Yes, HDs by-pass is in a different location.
rmsimmonsjr
I would love to do this together with someone who has experience. I will pay and also help so I can learn. Im in Southern Cali (Yorba Linda) if anyone would be willing to help. I have a 2023 TRX. PM me. Thanks everyone.
Matthias Hpunkt
If anybody doesn’t want to spend the money for the entire door harnesses and rear facia harness, and doesn’t feel like building the add on harnesses with the parts, let me know and I can build them for you-
Hello, I am from Germany. Deliver to Germany? Please, can you write me a message and tell me how much I have to pay for it? Thx
aeriosv
I just finished my installation. It was easy with the @Jimmy07 cables, thanks for the fast turnaround. If anyone in Connecticut needs some help with it, I can lend a hand!
JustARam23
The bypass is installed behind the gauge cluster. The dash doesn't need to be removed.
Okie22
Spent several hours this weekend modding my truck to have passive entry and it works flawlessly. Thanks to @MayhemMOORE for the awesome work putting everything together and @Jimmy07 for the top-notch harnesses.
Next mod will be adding power folding mirrors
rnaude241
Just a heads up for any Anvil BTS owners. I noticed during research you can get PE and regular handles in Anvil - because it was a color for the TRX.
I know this generally isn't possible for other BTS colors, and there's been some discussion here about possibilities/alternatives.
Does anyone know the part numbers for Anvil? I have a BTS in Anvil and was thinking of performing this mod with color matched handles instead of gloss black.
@Justineden
Can someone help!! I just put the doors and antenna in showing up on uconnect but the doors won’t unlock
MannyN
Did you put the old door handle caps on or new ones. The new ones should have a small magnet in them.
@Justineden
I put the old driver side one on but changed the passenger side. I will the driver side one today
mattee
How much do you charge for the passive entry harnesses?
Thanks
NateT
Configuring the BCM for passive entry with AlfaOBD.
Grab your SGW bypass and locate the Security Gateway. If you are unfamiliar with its location, it is located up inside the driver’s side footwell, behind where the headlight/parking brake switches are. The below pic shows the module, looking directly up from the floor. It's the black box with 2 connections on it, located right by the green and white star connectors.
*From what I have read, the bypass on the HD's is located behind the instrument panel and is a little more involved to access. Once I can confirm this and possibly get a photo of its location I will update this.
Release the connectors from the gateway and plug them into your bypass. That’s all there is to it.
Next, plug your OBD interface into the OBD port, which is located on the bottom edge of panel under the steering column. You should have no issues locating it, as it’s the only exposed connector in that area and will match up with your interface. If you haven’t done so already, set up your OBD interface with your tablet or computer via a Bluetooth or wireless connection.
With your foot off the brake pedal, press the Start/Stop button on the truck 2 times to place the ignition in to “Run”. Do not start the truck, just cycle the ignition to the “Run” position.
Once that is done, we are ready to make the changes in AlfaOBD. I opted not to include photos here since if you follow the steps one at a time you should have no issues. I do have screenshots, so if you need a visual to go along, I can get them added in.
Open up the app on your device and you should see the home screen.
To begin, click on the Bluetooth or Wi-Fi icon and connect to your OBD interface.
Once connected, select the Dodge/Ram icon.
On the first drop down menu choose your vehicle model.
On the 2nd drop down select “Body Computer”.
On the 3rd drop down you will need to select the appropriate BCM for your vehicle. For my 2020 I chose the very last one in the list.
The app should advance to a new screen where you can connect to the body computer. Once connected, it’s time to get in to making the changes needed.
Select the little icon in the bottom right that looks like a car with the hood open.
Select the drop down menu and go all the way to the bottom and select “Car configuration change”.
You should now have 2 additional drop downs below the top one. The top one will still say Car configuration change, and we aren’t going to mess with that one anymore. The next one down, the middle one, is where you are going to begin selecting the items to change.
Take your time and be sure you select the correct one each time as you proceed. To keep things simple, just start at the top and go down the list below, enabling and/or verifying each item as you go.
After selecting a setting to change in the middle drop-down, you will then select the command using the bottom menu. Reference the list below and make your selection based off the setting in bold.
After selecting the command in the bottom menu, hit “start”. The app will first verify the vehicle setting and give you a message indicating its current set state. If its current state is not set to what it shows in bold in the list below, press “start” again and this will make the change. You should get some text at the bottom saying the procedure was completed, however it did not always come up for me. If it doesn’t say it was completed, just hit start again and it will check the current status and tell you what it is. If it’s correct, move on to the next one.
The following list is all the settings you need to change or verify to enable Passive Entry. Each setting name is given, followed by the state it needs to be set to in bold. I made all the changes sequentially without cycling the ignition at all in between and everything worked just fine. Take your time as the full list in the app is long and you can easily scroll past a setting, especially the wireless ones as there are only a few. (The newer version of AlfaOBD allows you to search for a specific setting, so you can begin typing in the search bar and it will start narrowing down the list if you don't want to scroll through everything. Just make sure you keep track of the ones you change as you move down the list)
PASSIVE ENTRY BCM SETTINGS
VehConfig 3 fobik safe enable- YES
VehConfig 3 passive entry present- YES
LIN and Misc fobik safe alert no reply- YES
LIN and Misc fobik safe alert on system fault- YES
LIN and Misc fobik safe alert on search timeout- YES
LIN and Misc fobik safe alert per ignition cycle counter- 2
Wireless AP1 Left front- SMART SWITCH
Wireless AP2 Right front- SMART SWITCH
CustSetMenu 1 passive entry CSM present- YES
Cust.Prog.Features- Passive Entry Unlock All Doors or Approach Door- ENABLED
IMPORTANT NOTE:
With the configuration set as above, if you do not have all the hardware installed (such as the 5th antenna) fobiksafe will not operate as designed and there will be fault codes stored in the rfhub. If you utilize the inside lock button to lock the doors as you exit, whether or not the fob is inside, you will get an alert from fobiksafe and the locks will auto-unlock after closing. There is the small chance you could lock your fob in the truck if you ignore the warning since it doesn't actually know whether the fob is inside or not, and on the 3rd attempt the doors will remain locked. Once everything required for PE is installed, the whole system will function as intended from the factory…alerting you only if it senses a fob left inside the truck so you do not lock yourself out.
Once all the settings have been made you can cycle the ignition back to off. You can also remove the SGW bypass and OBD interface now.
Go ahead and disconnect the battery and let it sit for a bit. Anywhere from 15-30 min should be sufficient. The intent is to ensure the RF Hub re-reads and picks up on the new BCM configuration the next ignition cycle. (Although this may not be totally necessary, it isn't going to hurt anything)
This was initially completed on my '20 Bighorn which had the 8.4 non-nav unit. If you have nav, it may take a bit longer to show up in Uconnect, so don’t freak out if it isn't there right away. Give it a few ignition cycles and everything should show up. The actual passive entry will likely function even before the setting shows up in the menu. You will be able to find the passive entry option in settings, under “doors and locks" on your screen.
If you plan on adding the antenna and wiring to the rear of the truck, refer to the post that pertains to your specific model year.
I have finished all the steps but I use jscan instead of alfaobd and I can not find the setting besides just turning on proximity locks is it possible to do with jscan or do I need to get alfaobd? Is it possible my truck being a 2019 ram 3500 tradesman it won’t work or maybe won’t work because of my after market radio?
Garvanzo
Hello everyone, I have a problem with the programming. In Alfa obd I go to the section car config change and find the options as listed but keep getting procedure failed message. Anyone run into this?
