Ramduke
Hello everyone,
After receiving some feedback, it was brought to our attention that Uconnect 4/4C users would like to have their soft reset/reboot instructions easily accessible. For all of your convenience, you may find the instructions below.
Soft Reset
1. Put your vehicle into the accessories mode (ACC or RUN)
For keyless start (push-button) vehicles: push the start button twice without having your foot on the gas or brake pedal
2. Hold down the Phone and voice recognition buttons (or tuner and volume knob), at the same time, for thirty seconds.
3. Let go of the buttons
4. Turn the vehicle off
5. Open driver’s side door for thirty seconds (or until dash illumination goes black)
6. Close door
7. Restart vehicle
8. Let the media center load up and see if the concern is still present
If you're currently experiencing concerns and a soft reset of your system does not mitigate these concerns, please do not hesitate to send our team a private message with your VIN and a photo of your Uconnect system information so we can look into it for you.
Thanks,
Ram Cares
Hello,
I’ve got a 2019 1500 Laramie with the 8.4 Uconnect. Had the first head unit replaced because of the rear camera just displaying black and would continue to lock up the whole system. Now I have a bubble in the screen, brought it to the dealer and they said unfortunately they see this more than you’d think, so they opened up a case for me. Still waiting for a response from Ram Customer Support. There has been another issue since day one and in both head units, and that is when you select a different “theme” setting and the info screen between the gauges matches the Uconnect it only stays in the theme chosen until you shut off and restart the vehicle. Is there to your knowledge any fix for this? Having that theme feature is a nice touch and I would like to enjoy it the way it was intended.
Thank you!
Scott
Vin# 1C6RREJT1KN666963
Hello,
Thank you!
Scott
The theme setting is only permanent on Navigation models.
Ramduke
I have navigation.
Curious why you’d assume that I don’t moreover why would FSA even put a theme option if the intended outcome was to revert back? Doesn’t make sense.
I have navigation.
Why would I assume you don't? Because the theme isnt staying to what you changed.
RamCares
Michigan
Hello,
Thank you!
Scott
Hi Ramduke,
I was able to locate your case with the Ram specialist team and updated the case about your concerns here, but you can send us a PM to discuss your additional concerns further.
Steph
Ram Cares
Scram1500
Been trying the soft reset for the last few weeks with no success. Just discovered the vent fan/HVAC system must be off for this to work
ihaseebmalik
Hello everyone,
Soft Reset
6. Close door
7. Restart vehicle
Thanks,
Ram Cares
Im having issues with my back up camera on 2019 ram 1500 tried reseting the unconnect system it didnt worked all im getting is a black screen when put the truck in reverse tried checking for updates but theres no update for my system.
Check the connection in the tailgate
RamCares
Michigan
Hi there!
Our team would like to look further into this. May you please private message us, so we can see how we can best assist?
Gia
Ram Cares
BONUSTONUS
I have an issue with my 2018 Durango's radio. It's like there's a ghost constantly touching the screen. I tried doing the soft reset by hitting the phone/voice buttons and also the volume/tuner buttons, but nothing happened. I also made sure that the AC was off just in case. Does anyone have a suggestion?
Ask on a Durango forum
