Pics / stats of Actual Payload Labels
TrojanRam
Hi all, wondering if any of you that have a Wagoneer or GW with a decent number of options could share your actual payload ratings (compared to theoretical/ max advertised). I’m trying to figure out how much of a decrease we are likely to see once we add options as compared to the spec sheets. Thanks in advance!
bigdodge
Happy Ram Owner
this forum mostly talks about ram 1500's
TrojanRam
Right, posted here as this is the W/GW discussion channel. I also tried posting/ will post on the Wagoneer forum too but having an issue with registration there (and it’s fairly quiet).
Scram1500
To get you in the ballpark, a 4wd Tradesman has a payload around 1900 lbs, a fully loaded Limited can be as low as 950 lbs. The average Laramie is 1500 lbs.
TrojanRam
Thanks, I have spent a lot (too much lol) time reading the towing thread with the 1500 labels - my limited is one of those on the low end with 1068!
I’ll probably try to hit a dealer and take a look at some, if I find anything interesting I’ll share back.
WXman
Kentucky, USA
I looked at a Grand Wagoneer with the Hurricane I-6 engine. Payload on the sticker was 1450 lbs.
