UncaBuddha
- Aug 14, 2020
Got the top all wired up today. That wiring harness worked like a champ! Going to go camp out in the back this upcoming week and check for leaks etc.!
Agree! The Leer wiring harness is priceless.Got the top all wired up today. That wiring harness worked like a champ! Going to go camp out in the back this upcoming week and check for leaks etc.!
I found the pigtail also, was on top of the frame with about 1/4" sticking out, it was not visible from below but easy to feel. It was taped to the top of the wiring harness directly above the hitch bolt.Yes, Robalo2718 you are correct. My 2021 1500 Laramie has this pigtail (white/purple tracer) capped in black shrink wrap in the exact location as Ammdrew's diagram on post#48. You only need to take off a wrap or two of the fabric tape to access--I could actually feel the end cap under the wrapping. The rest of the harness can be left alone. This makes hookup of the CHMSL super easy (just connect the ground to the frame somewhere). No need for extra harnesses and logic modules to tap into the 7-pin trailer harness. Thank you everyone for your help!
Now, to figure out where to tap into to hook up the dome light so it works in conjunction with the factory LED bed lighting...
Couldn't find it on my 2019.So just to clarify, has anyone found this wire on the 2019's? Or is it MIA til 2020 models? I've looked and can't find it on mine.
View attachment 85279 View attachment 85280 View attachment 85281 View attachment 85282
See Post #88 above for an easy method.I have an ARE V series with the dome light and LED strip lights that i just bought off a truck at a dealership. Where do i tap into to get the LED and dome lights working?? my truck doesnt have the OEM bed lighting
Well I have a 2021 RAM, built Aug 9, 2021. I purchased a Y-connector harness that tees off the 7 pin connector, from eTrailer, and converts to 4-pin pig tail. Added a 4-pin extention and ran covered up behind tail light into truck bed along with a power wire that I soldered into Aux-12 volt off the 7-pin. Ordered a $15.00 electronic connector that, connects into my 4-pin trailer harness and converts turn/brake lights on harness into brake light.Has anyone done this yet? Still looking for good options while I wait for toppers to release
To be honest, I didn’t utilize the pigtail even though my truck has it. Instead, I splurged and purchased the kit below which a much cleaner installation as it provided the brake light as well as power for the interior lights of the topper.
Third brake light 7-Way Interface plug-in T Harness - 300100
Fits most trucks with 7-way trailer plugs #300100 Will not fit 2020+ new body style Chevy / GMC trucks with the Smart Tow and Advanced trailering system and 2015-2024 Ford F150, 2016-2024 F-250 and 2016-2023 Toyota Trucks (Tacoma and Tundra)www.ezwheeler.com
I tried it just now and the link works fine.Anyone have another place that has this harness?
I can't get their site to load.
It should.gotta love technology.... still doesn't work on my end but ill try and fight that battle another day.
Looking to make sure it works with this [see attached] I have partially installed; albeit hacked away at when the previous owner sold it to me:
First time posterYes, Robalo2718 you are correct. My 2021 1500 Laramie has this pigtail (white/purple tracer) capped in black shrink wrap in the exact location as Ammdrew's diagram on post#48. You only need to take off a wrap or two of the fabric tape to access--I could actually feel the end cap under the wrapping. The rest of the harness can be left alone. This makes hookup of the CHMSL super easy (just connect the ground to the frame somewhere). No need for extra harnesses and logic modules to tap into the 7-pin trailer harness. Thank you everyone for your help!
First time poster
2021 ram 1500 with the lights in the bed
Just got a new leer cap with a dome light
I’ve found the white and purple wire under the truck and a good spot for a ground I think, but where do I hook the third wire up to have the dome light work in conjunction with the bed lights?
I’m assuming to the red wire that’s behind the drivers side light that has the power button
Thank you
