Hennessey Offers 6-Piston Brake Upgrade For Ram TRX MAMMOTH™ 1000
Engineered To Fit Inside 18-inch Stock TRX Wheels...
Hennessey, the renowned Texas-based hypercar manufacturer and creator of high-performance vehicles, has recently unveiled an impressive upgrade for its formidable MAMMOTH™ 1000. The MAMMOTH 1000, based on the RAM 1500 TRX, already boasts an incredible 1,012 horsepower and 969 lb.-ft. of torque from its improved supercharged 6.2-liter HEMI® HELLCAT V8 engine. Hennessey has introduced the Monster 6-Piston Brake Upgrade to complement the immense power output, a comprehensive braking system enhancement designed to enhance stopping performance and safety.
The standard RAM TRX has 2-piston pin-slider calipers and 14.9-inch x 1.2-inch iron rotors on the front axle. In contrast, the Hennessey Monster Brake Upgrade features massive 6-piston heavy-duty calipers gripping new 14.8-inch x 1.65-inch iron rotors. These upgraded rotors are 37% thicker than stock, offering a 12% increase in thermal braking capacity. This substantial improvement in braking power significantly reduces stopping distances, ensuring optimal safety on and off the road.
The Hennessey Monster Brake Upgrade enhances stopping power and maximizes brake torque and service life. The oversized pads included in the upgrade increase available brake torque by up to seven percent, delivering enhanced braking force. Moreover, these pads reduce braking temperatures, thus extending the service life of the braking system. The result is a harmonious combination of power and control for the MAMMOTH 1000.
To match the rugged nature of the TRX MAMMOTH, Hennessey has used premium materials and robust construction for the Monster Brake Upgrade. The brake calipers are crafted from spheroidal graphite iron or ductile iron, ensuring high resistance to impact and fatigue. Corrosion-resistant zinc plating and a vibrant red epoxy acrylic paint finish adorned with the HENNESSEY script give the calipers an appealing appearance. The upgrade also incorporates forged billet aluminum and stainless steel components, guaranteeing durability and reliability.
Hennessey has designed the MAMMOTH Monster Brake Kit to fit all MAMMOTH 1000 builds, regardless of the wheel size ranging from 18 inches to 20 inches. Furthermore, the system is fully compatible with the original stock equipment Anti-lock Braking System (ABS) and Electronic Stability Control (ESC). Enthusiasts seeking to augment their MAMMOTH 1000’s braking capacity can order the Monster Brake Kit directly from Hennessey by calling +1 979.885.1300 or visiting the official website at HennesseyPerformance.com.
Hennessey Performance MAMMOTH TRX Brake Upgrade Image Gallery:
You must be logged in to post a comment.
