RECALL: 2025 Ram 1500 for Tire Pressure Display Error
Software Glitch May Cause Overinflated Tires, Increasing Crash Risk
Stellantis (FCA US, LLC) is recalling approximately 10,396 units of its 2025 Ram 1500 (DT) pickups due to a software error that may cause an incorrect tire inflation pressure message to display on the instrument panel cluster (IPC). According to the automaker, the incorrect tire pressure message may result in improperly inflated tires, increasing the risk of a crash.
The recall states that the IPC can list an incorrect “Inflate to: 50 PSI” message, instead of the correct recommended inflation pressure, resulting from a low tire pressure condition displayed in the IPC. Customers following this message could inflate a tire beyond the maximum pressure limit in some tire configurations. Tires inflated beyond their maximum pressure rating may increase the risk of a blowout, which could lead to a vehicle crash without prior warning.
The suspect period began on October 3, 2023, when the first suspect 2025 model year vehicle was produced, and ended on March 6, 2025, when the last suspect vehicle was produced. The suspect population was determined using vehicle production records.
Similar vehicles not included in this recall were built before or after the suspect build period or had different tire configurations and/or different IPC designs.
Recall Chronology –
On January 9, 2025, the FCA US, LLC (“FCA US”) Technical Safety and Regulatory Compliance (“TSRC”) organization opened an investigation into some 2025 Ram 1500 vehicles displaying an incorrect tire pressure inflation recommendation in the IPC.
From January 2025 through March 2025, FCA US TSRC met with FCA US engineering and manufacturing to review the issue, understand the failure mode, review customer records, and determine the suspect population.
As of March 28, 2025, FCA US is aware of zero customer assistance records, 15 warranty claims, 23 field reports, and two other service records potentially related to this issue for all markets, with dates of receipt ranging from September 24, 2024, to February 5, 2025.
As of March 28, 2025, FCA US is not aware of any accidents or injuries potentially related to this issue for all markets.
On April 3, 2025, FCA US, through its Vehicle Regulations Committee, decided to conduct a voluntary safety recall of the affected vehicles.
Dealers will update the instrument panel software, free of charge. Owner notification letters are expected to be mailed May 8, 2025. Owners may contact FCA customer service at 1-800-853-1403. FCA’s number for this recall is 30C.
Owners may also contact the National Highway Traffic Safety Administration (NHTSA) Vehicle Safety Hotline at 888-327-4236 (TTY: 888-275-9171) or visit nhtsa.gov.
You must be logged in to post a comment.
