Wiring LED light bar to turn on with LED factory high beams
JCLAYTON13
I just bought a new 2020 Ram Rebel and I want to install a light bar with the ability to have it turn on and off with the factory led high beam headlights. When I looked in the fuse panel I did not see a fuse or relay for the headlights to tap into for the 12v signal. Has any done this setup on the 5th gen Rams with factory led headlights?
5thGenRebel_AMK
PA
following this, it would be great to have my light bar turn on with the high beams as well
JCLAYTON13
Thanks All_Black_Lone_Star, do you know which wire is the high beam?
